Hai there,
There are many templates (html responsive) that you can build to a WBCE template.
I'm running now and then against the following:
Some templates goes out from TopMenu items whitout link in it. Its just to open up the menu under this.
Sometimes the small menu for Phones has a closed menu.
In WBCE there is always? a link on the top item. So when we click to open the top, you get to the site instead of opening the submenu.
If you know what i mean.
Is there a way to have menu items (top) whiteout link on it ?
So i can easy take that kind of template to.
Its not easy for me to change the nav js. systems in the templates.
Thank you in advance.
Greetings, Niek (NL)
There is a solution, you can see it for example in the "Buschwerk" template. You have to use conditional cases in the show_menu2 call:
$mainnav = show_menu2(
$aMenu = 1,
$aStart = SM2_ROOT,
$aMaxLevel = SM2_ALL,
$aOptions = SM2_ALL|SM2_PRETTY|SM2_BUFFER,
$aItemOpen = '<li><a [if (class!=menu-expand) {href="[url]" class="[class]" target="[target]"}]>[menu_title]</a>',
$aItemClose = '</li>',
$aMenuOpen = '<ul>',
$aMenuClose = '</ul>',
$aTopItemOpen = false,
$aTopMenuOpen = '<ul class="chevron">'
Have a look at the initialization of $aItemOpen: The code [if (class!=menu-expand) {href="[ url ]" class="[class]" target="[target]"}] (note the square brackets) tells show_menu2 not to set the href tag so that the entry itself does not open any link but just show the sub menu when pointing on / touching it. The same way it can be done for other menu scrips - it depends on each implementation how the code has to be set in detail, but the concept is the same.
Feel free to post the example code of the menu here, if you need help configuring the show_menu2 call.
Thank you, SM-2_PRETTY is showing now menu at all.
But when I only changed the aItemOpen, to your suggestion it works !
Thank you very much.
The only task for SM-2_PRETTY without the -! is to beautify the HTML-Output for better readbility.
