In de logging heb ik dit gevonden:
2024-02-19T11:06:36+00:00 [User Warning] /modules/outputfilter_dashboard/functions.php:[1266] from /modules/outputfilter_dashboard/functions.php:[1721] opf_apply_filters "failed to apply filter Droplets"
2024-02-19T11:06:36+00:00 [User Warning] /modules/outputfilter_dashboard/functions.php:[1266] from /modules/outputfilter_dashboard/functions.php:[1721] opf_apply_filters "failed to apply filter CSS to head"
2024-02-19T11:06:36+00:00 [User Warning] /modules/outputfilter_dashboard/functions.php:[1266] from /modules/outputfilter_dashboard/functions.php:[1715] opf_apply_filters "failed to apply filter Move Stuff"
Ze doen het ook niet
Kijk maar eens op https://freerkjongsma.nl/main/
in de rechterzijkant staan ze nu als klare tekst.
Wat zou er misgegaan zijn?
Freerk Jongsma
The page is not rendered properly.
Since this happens only on the homepage, this might be an issue with the modules used there.
If you call certain droplets only on the homepage, check their syntax and try to remove them from the homepage to find out which droplet causes the error.
Een oude versie (1.5.4) had het gewoon moeten doen.
Maar een update naar versie 1.6.2 was voldoende; alles werkt weer.
¯\_(ツ)_/¯
So why did you ask first? Was this a kind of test?
