This is a droplet to Display the Open Streetmap on WBCE.
Parameters:
lat = Latidude
lon = Longitude
zoom = Zoomlevel of map
height = height of displayed map
Use it with
[[osmkarte?lon=47.890&lat=13,456&zoom=15&height=400]]
have fun.
// usage: [[osmkarte?lon=&lat=&zoom=&height=]]
// parameters:
$lon = isset($lon)? $lon : 0;
$lat = isset($lat)? $lat : 0;
$zoom = isset($zoom) ? intval($zoom) : 19;
$height = isset($height) ? intval($height) : 400;
$content ="";
$content .=' <link rel="stylesheet" href="https://unpkg.com/leaflet@1.0.3/dist/leaflet.css" />
<script src="https://unpkg.com/leaflet@1.0.3/dist/leaflet.js"></script>
<style>
#map { height: '.$height.'px; }
</style>
<script language="javascript">
function init() {
var map = L.map(\'map\');
L.tileLayer(\'https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png\', {
attribution: \'© <a href="http://openstreetmap.org">OpenStreetMap</a> contributors\',
maxZoom: 18
}).addTo(map);
map.attributionControl.setPrefix(\'\'); // Don\'t show the \'Powered by Leaflet\' text.
var ort = new L.LatLng('.$lat.', '.$lon.'); // geographical point (longitude and latitude)
map.setView(ort, '.$zoom.');
var marker = L.marker(['.$lat.', '.$lon.']).addTo(map);
</script>
<div id="map" onload="javascript:init();"></div>
return $content;Offline
thanks
I don't get this working, sorry. Tested wth WBCE 1.1.11 and 1.2 alpha10, but I don't view a map and unfortunately not even JS errors.
The generated code looks like this:
<div> <link rel="stylesheet" href="https://unpkg.com/leaflet@1.0.3/dist/leaflet.css" />
<style>
#map { height: 400px; }
</style>
function init() {
var map = L.map('map');
L.tileLayer('https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png', {
attribution: '© <a href="http://openstreetmap.org">OpenStreetMap</a> contributors',
maxZoom: 18
}).addTo(map);
map.attributionControl.setPrefix(''); // Don't show the 'Powered by Leaflet' text.
var ort = new L.LatLng(13,456, 47.890); // geographical point (longitude and latitude)
map.setView(ort, 15);
var marker = L.marker([13,456, 47.890]).addTo(map);
</script>
</div> Do you have an idea what could cause the problem?
Der Fehler dürfte da liegen:
Dachte ich auch, aber das wars nicht
Wenn man jetzt noch lat / long vertauscht und das "onload" in den body verfrachtet, scheints zu klappen...
Kann ich soweit bestätigen.
<body onload=""> aus einem Droplet heraus setzen geht aber nicht so ohne weiteres. Hm.
Edit: Ergebnis von "Hm" (Denkvorgang)
Man müsste dann noch
$wb_page_data = str_replace('<body','<body onload="javascript:init();"', $wb_page_data);ins Droplet einfügen.
Beitrag geändert von florian (06.03.2017 12:29:56)
das Komma stört, muss ein Punkt sein....
<p> <link rel="stylesheet" href="https://unpkg.com/leaflet@1.0.3/dist/leaflet.css" />
<style>
</style>
function init() {
maxZoom: 18
}).addTo(map);
map.attributionControl.setPrefix('Setup by <a href="http://www.best-data.at">best-data</a> | Powered by Leaflet'); // Don't show the 'Powered by Leaflet' text.
var ort = new L.LatLng(47.90050, 13.78756); // geographical point (longitude and latitude)
map.setView(ort, 16);
var marker = L.marker([47.90050, 13.78756]).addTo(map);
</script>
</p>Der funktioniert bei mir...
Ev blockiert etwas anderes? Immerhin werden die scripte dirty nicht im header Tag ausgegeben sondern direkt beim droplet.....
ich wollte vorher die GPS-Koordinaten auch mittesl intval absichern, aber da schmeißt es alles nach der Kommastelle weg.
Ev hat da jemand eine einfache Lösung dafür....
schon klar, mir gings erstmal drum den Fehler zu finden und das war u.a die vertauschten lat/long.
In der Reihenfolge wie sie ursprünglich im Script stehen sagt der Geoconverter meines Vertrauens: "Geocoder failed due to: ZERO_RESULTS" - sprich ungültige Koordinaten müßten auch noch irgendwie abgefangen werden.
Wenn man davon ausgeht, das jquery eh geladen ist, könnte man das onload durch ein jquery document ready ersetzen ...
Also alle Quellen, die ich kenne, sagen klipp und klar das ein "onload" in einem div nicht funktioniert.
Mit welchem Browser, bitte klappt das bei dir?
Sodele, ein
<div id="map"></div>
<script>
window.onload = init();
</script>sollte es richten ...
Cool, so klappt es!
Anbei das Droplet mit dem Loader.
Ich arbeite ansich mit dem FF
Da ging das mit dem laden des Div....
Wie gesagt, das Kommastellenformat sollte man noch irgendwie abfangen.
Wie das mit lon/lat gehen soll, ist mir noch nicht ganz klar....
Beitrag geändert von berny (06.03.2017 13:16:34)
Das mit dem Komma vielleicht so (nicht getestet!):
$lon = isset($lon)? str_replace(',', '.', $lon) : 0;
$lat = isset($lat)? str_replace(',', '.', $lat) : 0;Und wegen ungültiger Koordinaten könnte man damit vielleicht was basteln:
errorTileUrl String '' URL to the tile image to show in place of the tile that failed to load.
oder damit:
locationerror ErrorEvent Fired when geolocation (using the locate method) failed.
Edit: kann man in dem Zusammenhang vergessen, der ErrorEvent feuert nur bei Verwendung der GeoLocationApi.
Nebenbe:, das ganze funktioniert auch ohne die init.Funktion und ohne onload, wenn man das map-div vor den Scripttteil setzt ...
Beitrag geändert von bernd (07.03.2017 01:03:38)
querdenker! Nicht gecheckt, sondern gleich angepasst...
Dass ich da nicht selber draufgekommen bin
Sehr schönes Droplet.
Leider erhalte ich die Java-Fehlermeldung "Map container not found." Ich habe auch mal das doppelte "window.onload = init();" gelöscht, nun ist der Fehler weg, aber es gibt auch keine Karte
Was tun?
Gruß ans Forum!
masju
PS (Nachtrag): Seltsam, auf einer anderen Seite von mir läuft das Droplet problemlos. Hatte also zuerst mein Template in Verdacht, aber auch bei einem "blank" kommt der Fehler. Ich forsche mal weiter...
Beitrag geändert von masju (26.04.2017 16:07:32)
Hallo und willkommen masju,
ich vermute mal, Du setzt WebsiteBaker ein? Eventuell schießt da ein Outputfilter quer.
Wie sieht denn der generierte Code im Frontend (Browser-> Strg-U) aus?
genau: WB 2.8.3 SP7.
Ich schalte mal im Outputfilter alle Optionen aus (außer natürlich Droplets
) Vielleicht liegt es wieder mal daran. Danke für den Tipp.
Der ausgegebene Code sieht übrigens okay aus (bis auf das doppelte "window.onload = init();" )
Danke für Deine Antwort. Ich melde mich, wenn ich den Knoten gelöst habe.
Gruß, masju
Hier noch der ausgegebene Code:
[[osmkarte?lat=47.890&lon=13.456&zoom=15&height=400]]
ergibt
[== HTML ==]
function init() {
maxZoom: 18
}).addTo(map);
var ort = new L.LatLng(47.890, 13.456); // geographical point (longitude and latitude)
var marker = L.marker([47.890, 13.456]).addTo(map);
</script>
<script>
</script>
</p>Offline
Ich vergleiche gerade den Output mit dem in WBCE.
Einziger Unterschied: bei Dir fehlt das
<style>
</style>Ist das irgendwo anders zu finden?
bei Dir fehlt das
<style> #map { height: 400px; } </style>Ist das irgendwo anders zu finden?
Nein, fehlt tatsächlich.
Ich habe alle Output-Filteroptionen abgewählt. Trotzdem keine Karte.
<style>
</style>
War tatsächlich die Lösung
! Irgendetwas filtert den Style heraus, trotz weitgehend abgeschalteter Optput-Filter. Nun habe ich ihn quasi mit der Brechstange in den <head>-Bereich geschrieben (Backend - Optionen - Kopfzeile), und alles läuft
Vielen Dank noch mal an den Entwickler für das schöne Droplet. Ich hatte schon vor einiger Zeit mal mit leaflet experimentiert aber es nicht zum Laufen gebracht. (jetzt weiß ich auch, warum).
Du könntest sonst
#map { height: 400px; }im Template-CSS einfügen, dann brauchst Du die Kopfzeilen-Brechstange nicht.
Ich habe im WB-Forum mal nachgefragt, es liegt am eingebauten CSStoHead-Filter von WB, der versucht, style-Anweisungen W3C-konform in den head zu verschieben, was in diesem Fall bei droplets aber schiefgeht (WBCE scheint diese Funktion nicht zu haben?).
Der User jacobi22 hatte dann eine noch universellere Lösung:
Den <style>-Bereich ganz entfernen und die Zeile
<div id="map"></div>austauschen mit
<div id="map" onload="javascript:init();" style="height:'.$height.'px"></div>Die java-Fehlermeldung "Map container not found" wird in der Konsole zwar immer noch angezeigt, aber die Karte ist da
Anscheinend braucht der map-Container nur eine irgendwie aber konkret angegebene Höhe, dann läuft die leaflet-Ausgabe.
Viele Grüße,
masju
Zu jacobis "Tipp" hinsichtlich div-onload siehe
https://forum.wbce.org/viewtopic.php?pid=9815#p9815
Die Höhe dynamisch per Inline-Style zu übergeben, ist interessant; aber wenn eine JavaScript-Fehlermeldung (JavaScript ist was anderes als Java!) - auch wenn sie "nur" in der Konsole kommt - erscheint, ist das aber vermutlich leider auch keine Option, die unbedingt browserübergreifend verlässlich funktioniert.
WBCEs Css2Head reagiert nur auf <style type="text/css">, nicht auf <style>. Ob das ein Bug ist oder so beabsichtigt, vermag ich nicht zu sagen. Generell sind wir hier etwas entspannter bezüglich Benutzerbevormundung strikter Regeleinhaltung.
Nun ja,
das type-Attribut ist in HTML5 nicht mehr erforderlich, vieleicht könnte man das Css2Head bei Gelegenheit ja mal anpassen, das es auf beides reagiert.
Und was das init im map-div anbelangt (was wohl den Javascript-Fehler verursacht): da sind wir wieder bei meinem Posting #9 und folgende
