#1 28.08.2015 14:27:47
easyuser
WB_VERSION - Soll das geändert werden?
es gibt im Core noch öfters die Variable "WB_VERSION", und hier auch einige Entscheidungen.
Da ich mir nicht ganz sicher bin, welche Auswirkungen das hat, wollte ich es einfach nur einmal hier anmerken.
Soll dies ausgetauscht werden?
Search "WB_VERSION" (51 hits in 16 files)
  --- \wbce\admin\settings\save.php (2 hits)
    Line 147: $disallow_in_fields = array('pages_directory', 'media_directory', 'wb_version');
    Line 195:             . 'WHERE `name`!=\'wb_version\' AND `name`=\'' . $setting_name . '\'';
  --- \wbce\admin\start\index.php (2 hits)
    Line 85:                     'WB_VERSION' => WB_VERSION
  --- \wbce\framework\addon.precheck.inc.php (5 hits)
    Line 114:     $key_order = array('WBCE_VERSION', 'WB_VERSION', 'WB_ADDONS', 'PHP_VERSION', 'PHP_EXTENSIONS', 'PHP_SETTINGS', 'CUSTOM_CHECKS');
    Line 184:         case 'WB_VERSION':
    Line 188:                 if (!defined('WB_VERSION')) {
    Line 195:                 $status = versionCompare(WB_VERSION, $value['VERSION'], $operator);
    Line 199:                     'actual' => WB_VERSION,
  --- \wbce\google_sitemap.php (1 hit)
    Line 300:                 if ((version_compare(WB_VERSION, '2.7.0') <= 0) && $news['published_when'] > 0) {
  --- \wbce\install\save.php (1 hit)
    Line 354: . '(\'wb_version\', \'' . VERSION . '\'),'    // Legacy: WB-Classic
  --- \wbce\modules\backup\backup-sql.php (1 hit)
    Line 122:   "# Website Baker ".WB_VERSION." Database Backup\n".
  --- \wbce\modules\droplets\add_droplet.php (2 hits)
    Line 52:         if ( version_compare(WB_VERSION, '2.8.2', '>=') && WB_VERSION <> "2.8.x" )
  --- \wbce\modules\droplets\backup_droplets.php (2 hits)
    Line 32: if ( version_compare(WB_VERSION, '2.8.2', '>=') && WB_VERSION <> "2.8.x" )
  --- \wbce\modules\droplets\delete_droplet.php (1 hit)
    Line 30:     if ( version_compare(WB_VERSION, '2.8.2', '>=') )
  --- \wbce\modules\droplets\functions.inc.php (6 hits)
    Line 42:         if ( version_compare(WB_VERSION, '2.8.2', '>=')  && WB_VERSION<>"2.8.x" ) {
    Line 247:         if ( version_compare(WB_VERSION, '2.8.2', '>=')  && WB_VERSION<>"2.8.x" AND $export_id==0) {
    Line 328:         if ( version_compare(WB_VERSION, '2.8.2', '>=')  && WB_VERSION<>"2.8.x") {
  --- \wbce\modules\droplets\modify_droplet.php (2 hits)
    Line 30: if ( version_compare(WB_VERSION, '2.8.2', '>=')  && WB_VERSION<>"2.8.x") {
  --- \wbce\modules\droplets\save_droplet.php (2 hits)
    Line 38: if ( version_compare(WB_VERSION, '2.8.2', '>=')  && WB_VERSION<>"2.8.x" ) {
  --- \wbce\modules\droplets\tool.php (8 hits)
    Line 46: if ( version_compare(WB_VERSION, '2.8.2', '>=') && WB_VERSION<> "2.8.x" ) {
    Line 79: if ( version_compare(WB_VERSION, '2.8.2', '>=') && WB_VERSION<> "2.8.x" ) {
    Line 105:         if ( version_compare(WB_VERSION, '2.8.2', '>=')  && WB_VERSION<>"2.8.x" ) {
    Line 198:         if ( version_compare(WB_VERSION, '2.8.2', '>=') && WB_VERSION<>"2.8.x") {
  --- \wbce\modules\show_menu2\include.php (3 hits)
    Line 561:         if (version_compare(WB_VERSION, '2.7', '>=')) { // WB 2.7+
    Line 564:         if(version_compare(WB_VERSION, '2.9.0', '>=')) {
    Line 585:                 if(version_compare(WB_VERSION, '2.7', '>=')) { // WB >= 2.7
  --- \wbce\modules\wbstats\help.php (4 hits)
    Line 22:     <?php if (defined('WB_VERSION') && version_compare(WB_VERSION,'2.8.2','>')) { ?>
    Line 28:     <?php if (!defined('WB_VERSION') || version_compare(WB_VERSION,'2.8.2','<')) { ?>
  --- \wbce\upgrade-script.php (9 hits)
    Line 292: $old_wb_version = array(
    Line 293:     'VERSION' => defined('WB_VERSION') ? WB_VERSION : VERSION,
    Line 304:     if (version_compare($old_wb_version['VERSION'], '2.7', '<')) {
    Line 309:     $oldVersion = 'WB-Classic v' . $old_wb_version['VERSION'] . ' (REV: ' . $old_wb_version['REV'] . ', SP: ' . $old_wb_version['SP'] . ')';
    Line 480: if (version_compare(WB_VERSION, '2.8', '<')) {
    Line 680: db_update_key_value('settings', 'wb_version', VERSION);   // Legacy: WB-classic
#2 28.08.2015 16:32:16
norhei
Re: WB_VERSION - Soll das geändert werden?
Wenn ich mich richtig erinnere hatten wir gesagt fürs erste Release erst mal drin und die WB_VERSION bleibt auf 2.8.3(4?)
Deswegen gibt es noch die WBCE_VERSION.
Wir wissen halt nicht wofür genau das alles gebraucht wird , es muss sich halt Jemand hinsetzten und sehr genau schauen bevor er die Sachen rauswirft.
Und es kann halt was kaputt gehen.
#3 29.08.2015 10:26:07
cwsoft
Sollte drin bleiben. wird von einigen Modulen verwendet und wirft nene Fehler wenn nicht definiert.
#4 29.08.2015 22:10:29
norhei
Deswegen hatte ich ja damals vorgeschlagen bei WBCE mit 2.8.4 oder 2.9.0 einzusteigen ;-)
Einfach auf doof die ollen WB Dinger weiternutzen.
*malwiedermeinmaulnichthaltenkann*
