Hello
I would like to use Topics Module for writing articles without images.
I red that in older versions of the module there was setting in module_settings.php (use_pictures=0), but in the latest version it is not available.
Is that possible to switch off images in Topics module?
When I create article without image, there is php notice:
Notice: Undefined variable: thumb in D:\WAMP\www\...\modules\topics\view.list.php on line 346
Gawi
Cannot answer With my Smartphone in Englisch.
later. It is easy.
Back in the office..
Its not possible to switch off the pictures, but its easy not to use them.
Go to "settings"
> "overview page" -> Field "Loop" and remove the placeholder {THUMB}
> "topic" -> Field "Header": remove the placeholder {PICTURE}
> "See also, previous, next": remove the placeholder [THUMB]
If you have different Setting: please post them here.
The Topics-Picture: Simply use none or any one.
Hi
I have made all changes. Result - there are still php notices - one for each topic:
Do you think that I can just disregard this notice?
You can add the line
$thumb='';after
if (!isset($tablename)) { exit("No tables defined"); }at the top of the view.list.php, then the notice will vanish. (But it's just a notice anyway, so nothing "really" important).
Thanks a lot. It works
Cheers
