#1 29.06.2017 09:00:13
joyhill
Template styles
Hello
This could be a stupid question but I haven't found anything about that in English.
There are templates which have Bootstrap style and Teaser style for example Webezeheh, but how can I use it with those styles? What sould I do on index.php or .css or somewhere else that I can make page with for example Bootstrap style?
#2 29.06.2017 10:01:38
Re: Template styles
Have a look at Itemz, where you can find some presets which do the job or - with some HTML/CSS knowledge - quite effortless build your own teaser design; another option is the Teasers module, which comes with ready-styled teaser fields.
That means, you do not have to add special code to your template, all it's done  in an itemz or teasers section.
#3 03.07.2017 15:38:08
joyhill
Re: Template styles
OK. Looks like that Teasers working fine and easily. But how can I change my own images for Teasers' demo pics?
#4 03.07.2017 15:39:15
joyhill
Re: Template styles
And where I can change the Click! -link to my own language? Almost all codes Checked but didn't find... hmm
#5 03.07.2017 17:05:09
grindbatzn
Re: Template styles
Yes, that "Click" should be editable.
One is here: /teasers/kram/functions.inc.php Line  67
One mode is here: /teasers/frontend.js Line 144
Upload (is globaluplad installed?): https://wbce.at/downloads/globalupload.zip
So if:
