#1 27.03.2018 04:00:07
losttrip
Fatal Error
wbce 1.3.1
RFG 0.75
Everything works locally, but after I upload to the live server, I get this Fatal Error on both front and back end.
Fatal error: Call to a member function fetchRow() on null in /home/myserver/public_html/myroot/modules/responsiveFG/scripts/functions.php on line 32
Rest of site is working fine.
Any guidance would be greatly appreciated.
#2 27.03.2018 07:19:18
Re: Fatal Error
Sounds like the settings tables are missing. Please make sure that there is a mod_responsiveFG_settings table, including the fields s_name and s_value in the database.
The issue might be caused by the capital letters in the RFG folder name, the module uses it for its table names too, e.g. if you install the RFG in /modules/myfancygallery/, the module expects to find tables like "mod_myfancygallery_settings etc.
#3 27.03.2018 21:16:30
losttrip
Re: Fatal Error
The issue was the lack of upper case "FG" in the database table names.  Gallery is showing now.  Thank you!
there are a couple notices which display below the gallery thumbnails on the frontend (both locally and on the live server):
Notice: Undefined index: CB_START_SLIDESHOW in /home/myserver/public_html/mysite/modules/responsiveFG/view.php on line 844
Notice: Undefined index: CB_STOP_SLIDESHOW in /home/myserver/public_html/mysite/modules/responsiveFG/view.php on line 845
Any idea what is causing this?
#4 27.03.2018 21:25:32
Re: Fatal Error
D'uh, my mistake, seems I've missed to complete the EN.php.
Please add
$MOD_FOLDERGALLERY['CB_START_SLIDESHOW']   = "Start slideshow";
$MOD_FOLDERGALLERY['CB_STOP_SLIDESHOW']   = "Stop slideshow";
for a quick fix to /modules/ResponsiveFG/languages/EN.php.
Any other notices? (I'm sorry, I'm just working on sth. else at the moment and can't test it by myself now)
#5 27.03.2018 22:29:44
losttrip
Re: Fatal Error
That fixed those notices.  Thanks again!
When I first choose a root directory, I get this notice multiple times (for each image) above the thumbnails.
Notice: A non well formed numeric value encountered in \root\mywebsite\modules\responsiveFG\class\class.upload.php on line 2720
When I refresh the page (and all subsequent page views), the notices are no longer displayed.
#6 27.03.2018 22:34:34
Re: Fatal Error
This can be possibly fixed easily or with an update of the class.upload, see
https://github.com/verot/class.upload.php/issues/59
I will keep that in mind for a future update
#7 26.06.2018 01:57:10
tombal
Re: Fatal Error
Hallo Forum,
ich erhalte nach dem Upload auf den Seiten der Responsive FG folgende Fehlermeldung:
Fatal error: Call to a member function fetchRow() on null in /usr/local/www/apache24/noexec/steinmetz-kaspers.de/modules/responsiveFG/scripts/functions.php on line 32
Alle anderen Seiten funktionieren einwandfrei.
Offline im XAMPP läuft alles tadellos!
Wie lässt sich dieser Bug beheben? Durch Umbenennen der Bildtitel (nur Kleinbuchstaben ohne Sonderzeichen ausser -) wird es nicht besser.
Vielen Dank im voraus für eine schnelle Hilfe.
Tom
#8 26.06.2018 08:12:05
Re: Fatal Error
Hallo Tom,
die Lösung steht bereits (auf englisch) hier in diesem Thread in #2 und #3.
Kurzzusammenfassung:
gucken ob in der Datenbank die Tabelle mod_responsiveFG_settings vorhanden ist und auch wirklich so heißt, mit groß geschriebenem FG
#9 26.06.2018 09:57:01
tombal
Re: Fatal Error
Vielen Dank für die schnelle Hilfe!
Jetzt erhalte ich eine andere Fehlermeldung (Screenshot bleibt so):
Fatal error: Call to a member function numRows() on null in /usr/local/www/apache24/noexec/steinmetz-kaspers.de/modules/responsiveFG/view.php on line 215
Danke für die Mühe und Mitwirkung.
Beste grüße
Tom
#10 26.06.2018 10:02:42
Re: Fatal Error
Da wird nach mod_responsiveFG_categories gesucht, die Tabelle scheint dann auch nicht zu existieren bzw. anders zu heißen
Beitrag geändert von florian (26.06.2018 10:02:54)
#11 26.06.2018 10:16:03
tombal
Re: Fatal Error
Danke ! ! !
Nach dem Umbenennen in der DB (mod_responsiveFG_categories) erscheint nun:
Fatal error: Call to a member function fetchRow() on null in /usr/local/www/apache24/noexec/steinmetz-kaspers.de/modules/responsiveFG/view.php on line 450
Wo ist der "Wurm" drin? Danke im voraus!
#12 26.06.2018 10:16:58
Re: Fatal Error
mod_responsiveFG_files
#13 26.06.2018 10:23:24
tombal
Re: Fatal Error
Vielen Dank Florian,
nachdem ich nun alle 4 Tabellen von fg zu FG umbenannt habe, funktioniert es einwandfrei.
Es ist total SUPER!!!, dass ich als 64jähriger Dummie hier im Forum diese kompetente Hilfe erhalte.
Danke und eine gute Zeit!
Tom
#14 26.06.2018 10:24:09
Re: Fatal Error
Keine Ahnung, wieviele Tabellen die RFG hat,
aber um das bischen abzukürzen (auch für künftige Ratsuchende):
einfach kontrollieren ob alle Tabellen mod_responsiveFG_xxx auch wirklich so (Groß/Kleinschreibung) geschrieben sind.
Der "Mist" kommt wohl offensichtlich daher das sich Windows (XAMPP) nicht um Groß/Kleinschreibung schert, Linux (auf richtigen Servern) hingegen casesensitiv ist.
