#1 27.03.2018 23:12:10
losttrip
[erledigt] wsession throws warnings
I am not sure if this is related to this topic, but I get these two errors (every 30 minutes) in the root error_log:
[27-Mar-2018 20:30:02 UTC] PHP Warning:  session_start(): Cannot send session cookie - headers already sent in /home/myroot/public_html/mysite/framework/wsession.php on line 72
[27-Mar-2018 20:30:02 UTC] PHP Warning:  session_start(): Cannot send session cache limiter - headers already sent in /home/myroot/public_html/mysite/framework/wsession.php on line 72
I tried searching the forum, but didn't find anything I could try.
#2 28.03.2018 07:34:33
Re: [erledigt] wsession throws warnings
I've moved the post to the right forum. We will have a look at it.
Which PHP version?
Beitrag geändert von florian (28.03.2018 07:38:14)
#3 28.03.2018 10:29:34
losttrip
php version 5.6
#4 19.06.2018 10:06:44
I am going to fix this, but I must admit that I have no idea on how to figure it out. As the error occurs every 30 minutes only, it may depend on the settings of the webserver or is caused by a module. Could you send me a PN with some more details about your installation? Thanks in advance.
#5 22.06.2018 16:18:57
losttrip
Thank you for the offer to help.  But at this stage, I honestly can't remember the specifics of the issue I was experiencing at the time (three months ago).  I checked my error-log and no further entries were logged, so I either solved the problem, or it went away through a change.  I checked my notes and can't find a resolution.
I do remember I researched this error and found info on making sure there are no tabs, spaces or characters (hidden BOM) before the initial <?php
Reference:
https://stackoverflow.com/questions/881 … ready-sent
I'm only guessing at this point, but this might have been the issue, as I created this template in WB a long time ago, when I was just learning how to create my own templates.  Sorry, I can't offer more insight than this.
#6 26.06.2018 13:45:58
Thank your for your help. I'm happy to hear your problem is "solved". wink
