#1 12.04.2018 18:25:01
losttrip
Itemz new install Notices
I am trying Itemz for the first time, and am excited for the possibilities.
I just want to check to see if there is anything to be concerned about the following, before I get further into development.
I installed 0.9.5_1 on WBCE 1.3.1 locally PHP 7.1
There is already a group present "Group2", is that supposed to be there/is it necessary?:
I see these notices on the frontend (error reporting set to development):
Notice: Undefined variable: item_in_group in ...\modules\itemz\view.php on line 370
Notice: Undefined variable: item_in_group in ...\modules\itemz\view.php on line 412
Those notices go away if I add an Item, or if I delete that "Group2", but when I delete Group2 I get a briefly displayed notice in the backend:
Notice: Undefined index: delete_grp_items in ...\modules\itemz\delete_group.php on line 20
Then, if I delete the itemz section from a page, I see a Notice? (I don't know because I can not see all the text, but it points to:
...\modules\itemz\delete.php on line 27
I just wanted to find our if these might be caused by something I did wrong, or if they can safely be ignored.
Thank you.
Beitrag geändert von losttrip (13.04.2018 00:24:11)
#2 13.04.2018 06:12:38
Re: Itemz new install Notices
Yes, because without group(s), yo can't create items.
About the notices, they are just caused by untidy program code (undefined variables), but nothing to worry about.
#3 13.04.2018 06:24:57
losttrip
Okay.  Thank you for the reassurance.
#4 17.04.2018 17:06:13
losttrip
There was a notice in the backend and some unclear text.  For anyone interested, here is an updated English Language file for itemz_0.9.5_1.
#5 17.04.2018 20:07:53
grindmobil
Gast
Hi!
Yes, those notices appears in "extreme" cases: groups with No items, items with No Pictures....
Sorry, typical coder mistakes.
#6 17.04.2018 20:12:45
losttrip
No need to apologize.
The main reason for the uploaded file is that the English EN.php file was missing the following:
//New 12.2012
$ITEMTEXT['MAKE_ALIAS'] = 'Create Alias';
$ITEMTEXT['GOTO_ALIAS'] = 'Edit Original';
$ITEMTEXT['LONGUSAGE_CODE'] = 'PHP Code';
$ITEMTEXT['SORT_BY_STARTTIME'] = 'start time';
$ITEMTEXT['SORT_BY_STOPTIME'] = 'stop time';
I thought this addition might be helpful to other English users.
