Maybe this is a "known bug" but I didn't find anything here....
Just installed WBCE 1.0 and bs_naturak Template and have a strange issue with colorbox:
<script type="text/javascript" src="function URL() {
[native code]
}/modules/colorbox/js/jquery.colorbox-min.js"></script>
Oder spende an das Projekt.
No Idea right now
bs_naturak is a bootstrap template and loads its own jquery. The colorbox snippet does not work with this, I can confirm; but I can't reproduce the described error - do you mean, inside the generated code pops up "[native code]" or do I misunderstand you?
bs_naturak Template does not use "register_frontend_modfiles('jquery');" for loading jquery. When calling this function a js variable URL is set. So as this function is not used URL is not set.
To get around this define
[== HTML ==]
<script var URL ="<?php echo WB_URL;>"</script> somewhere before the frontend.js files are loaded
1.3.1 site
Google Webmaster tools, Google can only fetch pages "partial"
Report shows:
Googlebot couldn't get all resources for this page. Here's a list:
URL Type Reason Severity
http://www.mysite.com/function URL() { [native code] }/modules/colorbox/1/colorbox.css
Style Sheet Not found --
http://www.mysite.com/function URL() { [native code] }/modules/colorbox/js/jquery.colorbox-min.js
Script Not found
I tried adding the suggested code:
<script var URL ="<?php echo WB_URL;>"</script> But no matter where I place it, my site is a white screen - no output.
The code example has an error, try
<script>
var URL ="<?php echo WB_URL; ?>";
</script> Beitrag geändert von florian (18.04.2018 21:11:22)
That works perfectly.
Thank you so much!
