Hello
I have installed WBCE 1.3.3 on Wamp - local server.
I created new folder in media directory via backend. After then I decided to change its name. It was not possible. Warning was shown. So I wanted to remove folder via Total Commander but it was not possible.
Now when I select Media in CMS I have three warnings displayed - media catalogues are not displayed.
Warning: dir(D:\WAMP\www\fairms/media/home,D:\WAMP\www\fairms/media/home): Odmowa dostpu. (code: 5) in D:\WAMP\www\fairms\framework\functions.php on line 90
Warning: dir(D:\WAMP\www\fairms/media/home): failed to open dir: No such file or directory in D:\WAMP\www\fairms\framework\functions.php on line 90
Fatal error: Call to a member function read() on boolean in D:\WAMP\www\fairms\framework\functions.php on line 9
Can you help me with this problem?
Regards
Gawi
Beitrag geändert von florian (08.05.2019 06:23:09)
Ok. Problem solved.
I had opened GIMP in which I created picture that was written to media folder. So Gimp blocked that folder in Media directory.
When I closed GIMP Media folder in CMS works correctly.
