I have update 2 sites tot beta 1.1.3 last weekend... on both sites search is not working anymore .
Is this correct ? I use a droplet searchbox .. The box is there, but after entering search nothing is comming back.
Kind regards, and thank you in advance.
Made a quick test with a 1.1.3 RC, search seems to work properly. Maybe a module causes an error?
I know about an error in an older topics version which caused the search engine to break down.
So which addons are installed on these websites?
Does the search work on
yoursite.com/search/
Did you install new modules recenty?
No, I just dit 'n update to the Beta version .
After that i did not updated modules.
On both sites is Global Blocks. (Search is in the side bar)
- miniform - minigalary - responsive fg -
I wil see what i can find.
I clicked through your reference sites and found the updated sites where the search does not work any more.
The search result site is not built completely, so there must be a fatal PHP error. Can you switch on Error Reporting temporarily (Options => PHP error reporting to E_ALL or E_EVERYTHING) and then have a look if any messages are displayed and copy them here?
Please also: Which PHP version is running?
You can also have a look at the module directories and temporarily rename the search.php of the modules one by one and test the search again to find out the module which causes the error.
site 1:
Parse error: syntax error, unexpected ';' in /home/xxxxx/domains/xxxxxxxxx/public_html/search/search.php on line 143
Site 2:
Parse error: syntax error, unexpected ';' in /home/yyyyyy/domains/yyyyyy/public_html/search/search.php on line 143
I will look my self first.. this weekend, maybe there is a - end div - or div - missing in my template.
What maybe, after the update is creating a error, only when i use search ?
Greetings,
Beitrag geändert von foxlake (22.12.2015 23:27:07)
Are you sure you are using the cuurrent stable version of WBCE 1.1?
https://github.com/WBCE/WebsiteBaker_Co … cf964e3c9e
Sorry, you're absolutely right !
It was 1.1.2 and 1.1.3 Beta.
I just installed the stable 1.1.3 version over it, and its working now !
Merry Christmas !
And Greetings . WBCE is getting better every day !
