Hello!
I use WBCE 1.4 with template WBCETik.
I noticed, that the subitems in vertical menu needs doubleclick to open related submenu page.
How to avoid doubleclick?
Thank You.
yeah, unfortunately the script does not work properly - but I've found a better solution now.
1) change the line (in original template line 32)
$aItemOpen = '<li><a href="[url]" class="[class]" target="[target]">[menu_title]</a>',to
$aItemOpen = '<li class="[class]"><a href="[url]" target="[target]">[menu_title]</a>',2) Remove at the bottom (line 274)
$( '.chevron li:has(ul)' ).doubleTapToGoX();and instead, put there
$(document).ready(function () {
$('.chevron li').children('ul').hide();
$('.chevron li.menu-parent').children('ul').show();
$('.chevron li').click(function () {
if ($(this).children('ul,p').is(':hidden') == true) {
$(this).children('ul,p').slideDown('slow');
return false
});Then the behavoiur should be as expected/wanted:
- if a menu item is just a usual link, open it, either on which level it is
- if it's a parent item with submenu entries, display the submenu, and open the link of the parent item itself on the second click
Excellent! It works!
Big TNX!
