I am working with OneForAll OFA and am trying to do a check to see if the item image has an "alt" attribute set. If not, then I want to insert the item [TITLE] automatically for all images.
I have been trying to achieve this by editing the modify_item.php file line ~465:
<input type="text" name="images[<?php echo $img_id; ?>][alt]" style="width: 150px;" maxlength="255" value="<?php echo $image['alt']; ?>" />I can force it to use [TITLE] by changing it to:
<input type="text" name="images[<?php echo $img_id; ?>][alt]" style="width: 150px;" maxlength="255" value="[TITLE]" />But I don't want to force it or over any alt tag a user has imput. I want to check first. I've tried if else, but am doing something wrong, because I keep getting white screens.
Sorry for the noob question. Thanks in advance for your time.
You can achieve this by modifying the save_item.php. Change line
if (!empty($image['title'])) { $image['alt'] = $image['title']; }to
if (empty($image['title'])) { $image['alt'] = $title; }Offline
losttrip
Thank you for steering my in the right direction.
Because I want to maintain the ability to put custom text in the ['title'] Attribute dialogue and it NOT be automatically used if the 'alt' attribute is empty, I used this:
if (empty($image['alt'])) { $image['alt'] = $title; }So that ONLY the item TITLE is used, if the alt attribute is empty.
Well whatever, maybe I've understood you wrong. But you wrote this
what differs from this
But if you found a solution for your need, all the better.
Sorry, if I sounded ungrateful. I am not. I appreciated your help.
I was/am probably not being clear with my terms. I apologize.
Here is the item [TITLE] I am referring to:
and here is the image HTML ['title'] Attribute dialogue I am referring to:
In my test of your code solution:
if (empty($image['title'])) { $image['alt'] = $title; }It works perfectly IF the item image HTML ['title'] Attribute dialogue IS Empty. Then it uses the Item [TITLE] for the 'alt'. That's great!
...But if the HTML ['title'] Attribute dialogue is NOT empty, then the HTML ['title'] Attribute text is used for the 'alt' attribute... and I don't want that. I want to use the item [TITLE] for the alt (if the alt is empty).
I want users to be able to enter image HTML ['title'] Attribute text (which is shown as a tooltip when hovering the image) if they want, without that text being used as the alt.
This is what the solution I ended up using seems to accomplish. It's working for me at least.
Hope this helps somewhat to clarify.
Thank you once again.
