#1 27.10.2019 02:19:11
losttrip
Details page with only Long Content instead of both Short and Long
By default the NWI overview page shows the Short content, and "read more" link to the Details page if there is Long Content.
The Details page shows the Short Content followed by the Long Content.  [CONTENT] seems to automatically combine both Short and Long Content.
I only want the Long Content displayed on the Details page.  That way you can use the Short Content to serve as separate "tease" text which links to the full article, which is what is entered in the Long Content.
edit: I have implemented  bugfix release 0.1.2  - https://forum.wbce.org/viewtopic.php?pid=28178#p28178
With this version, if there is no Long text, but there is a Gallery, then the "Read More" link appears with the post on Overview page.  In this case, the Details page shows the Short text and the Gallery.  I do not want to lose this functionality of showing the Short Content on the Details page IF there is no Long Content.  I hope that makes sense.
Beitrag geändert von losttrip (27.10.2019 02:26:45)
#2 27.10.2019 07:10:55
Re: Details page with only Long Content instead of both Short and Long
Just use the placeholder [CONTENT_LONG]  instead of [CONTENT] .
#3 27.10.2019 15:49:14
losttrip
Where should I make this replacement?
I tried it here in the Post Settings / Post Content:
and the result on the Details page is just the placeholder text:
[CONTENT _LONG]
Beitrag geändert von losttrip (27.10.2019 15:49:59)
#4 27.10.2019 15:51:28
Use [CONTENT_LONG]  without space before _LONG
#5 27.10.2019 16:01:44
losttrip
I do not have a space, I have - [CONTENT_LONG]
[CONTENT_LONG]
Result on page:
Beitrag geändert von losttrip (27.10.2019 16:05:47)
#6 27.10.2019 16:14:39
I see. The NWI version 4.0.1 which is included in WBCE 1.4.0 has the CONTENT_LONG feature, the 4.0.0 release on Github does not.
Just download the attached view.php and replace the existing /modules/news_img/view.php with that one. Then it will hopefully work as expected.
#7 27.10.2019 17:12:47
losttrip
Thank you, it now functions as expected.
