#1 05.06.2020 18:36:52
keepshango
[solved] Remove “read more“ from one accordion header pane
Hi
MY CONFIGURATION
PHP 7.2.24
WBCE CMS 1.4.2 :
Thanks to help on the forum, I change a setting in file “accordion.inc.php“, so that “read more“ link accordion header panes is now translated in my preferred language.
*** Q1 ***
What further coding may be needed if I want to remove this link from one particular pane of the accordion header ?
Regards
Beitrag geändert von keepshango (06.06.2020 12:59:53)
#2 05.06.2020 19:14:58
Re: [solved] Remove “read more“ from one accordion header pane
One possible and flexible way would be:
On top of the file (e.g. after $read_more)  an array which contains the page-id(s) where you don't want the readmore-Link
$aNoReadMore = [17,25,99];
Than modify the $outp (line #77ff - after the comment //Start output) as follows:
$outp .= '<li><div class="hpanel"><img class="panelpic" src="'.$image_dir.'/'.$pic .'" title="'.$titlealt.'" alt="'.$titlealt.'" /><h2>'.$title.'</h2>'.$description;
if (!in_array($pid, $aNoReadMore)) {
     $outp .= '<br /><a href="'.$link.'">'.$read_more.'</a></div></li>';
As a result only the pages that are not in the above mentioned array will become the readmore link.
#3 06.06.2020 12:59:16
keepshango
It works fine, thanks  smile
