#1 07.06.2020 13:40:27
Slugger
Kein speichern des colorpickers - Lesefaken
der colorpicker speichert leider nicht meine neu eingestellten Farbeinstellungen.
Folgende Meldungen kommen.
#1 2020-06-07T12:31:00+00:00 [Warning] /framework/dbsession.php:[70] from /framework/initialize.php:[212] DbSession->__construct "session_set_save_handler(): Cannot change save handler when headers already sent"
#2 2020-06-07T12:31:00+00:00 [Warning] /framework/wsession.php:[42] from /framework/initialize.php:[215] WSession::Start "ini_set(): Headers already sent. You cannot change the session module's ini settings at this time"
#3 2020-06-07T12:31:00+00:00 [Warning] /framework/wsession.php:[47] from /framework/initialize.php:[215] WSession::Start "ini_set(): Headers already sent. You cannot change the session module's ini settings at this time"
#4 2020-06-07T12:31:00+00:00 [Warning] /framework/wsession.php:[56] from /framework/initialize.php:[215] WSession::Start "ini_set(): Headers already sent. You cannot change the session module's ini settings at this time"
#5 2020-06-07T12:31:00+00:00 [Warning] /framework/wsession.php:[66] from /framework/initialize.php:[215] WSession::Start "session_name(): Cannot change session name when headers already sent"
#6 2020-06-07T12:31:00+00:00 [Warning] /framework/wsession.php:[67] from /framework/initialize.php:[215] WSession::Start "session_set_cookie_params(): Cannot change session cookie parameters when headers already sent"
#7 2020-06-07T12:31:00+00:00 [Warning] /framework/wsession.php:[69] from /framework/initialize.php:[215] WSession::Start "session_start(): Cannot start session when headers already sent"
Hat da jemand eine Idee?
Status Projekt 1-4:  OK
#2 07.06.2020 13:44:15
Re: Kein speichern des colorpickers - Lesefaken
#3 07.06.2020 13:50:31
Slugger
Danke hat geklappt smile
