#1 23.07.2020 21:30:17
Automatic translation
I have added a clone of the default template Aira2 called Aira2_GT (GT = Google translate).
Go to Profile > Display to choose the mentioned template. Once switched to that template, you will find a language select box on the upper left on the page, where you can select one of several languages to which the forum will be automatically translated then.
Please be aware that
a) the translation is done automatically and will probably have some errors
b) a cookie is set to remember the selection
c) some data is sent to Google
