NWI Anywhere-Aufruf, so in einen Code2-Abschnitt eingefügt:
$config = array(
'group_id_type' => 'section_id',
'group_id' => 8,
'display_mode' => 3,
echo getImageNewsItems($config);erzeugt diesen Hinweis:
Notice: Undefined index: page_id in /var/www/wbce/modules/news_img_anywhere/include.php on line 318
Es handelt sich um eine neu aufgesetzte Seite (WBCE 1.4.5).
Beitrag geändert von florian (01.10.2020 09:49:23)
Danke für den Hinweis. Es müsste eigentlich genügen, in der modules/news_img_anywhere/include.php die fragliche Zeile 318
'PAGE_ID' => (int)$row['page_id'],zu entfernen.
viktor321j
WBCE Version: 1.4.4
PHP Version: 7.4.22
Having the same or similar issue.
Code 2 section:
$config = array(
'group_id_type' => 'group_id',
'group_id' => 0,
'display_mode' => 5,
'start_news_item' => 0,
'max_news_items' => 20,
'max_news_length' => -1,
'strip_tags' => false,
'allowed_tags' => '<p><a><img>',
'custom_placeholder' => false,
'sort_by' => 1,
'sort_order' => 1,
'not_older_than' => 0,
'lang_id' => 'AUTO',
'lang_filter' => false,
'skip' => null,
'tags' => null
// calling getImageNewsItems() without configuration array uses the defaults above
echo getImageNewsItems($config);Errorlog viewer is full of lines with this Notice each time the page containing the code2 section is viewed:
[Notice] /modules/news_img_anywhere/include.php:[318] from /modules/code2/view.php:[52] "Undefined index: page_id" This line you suggested is already included on line 318 of modules / news_img_anywhere / include.php
'PAGE_ID' => (int)$row['page_id'],Online
It's a translation issue. The line
'PAGE_ID' => (int)$row['page_id'],has to be removed.
losttrip
Thank you so much!
