#1 14.01.2021 01:59:26
paka
Installed version - where displayed?
Hello,
Yes this is a simple question and it's a bit embarrassing to even ask. But where/how can I determine which version of WBCE is installed on a server?  In this case it's not an install I did.
#2 14.01.2021 08:10:16
Re: Installed version - where displayed?
In the backend it depends on the backend theme. In WBCE Flat and Fraggy the version is usually shown in the left column below the menu items, in Argos reloaded in the footer.
In older versions of WBCE this information might not be displayed yet, in that case install the admin tool sysinfo and look on the tab "WBCE constants" for the value of "WBCE_VERSION".
If you do not have backend but only FTP access, you can find the version in the file admin/interface/version.php.
paka
