#1 08.03.2021 19:11:56
losttrip
[Solved] Different Background Colours on specific pages
I'm sure I've read how to do this in the past, but can't find any posts using (English) search.
How ca I set up my template and css to show a different background colour on different pages?  I don't want to load a different template for each page, if that's possible to avoid.
Thanks!
Beitrag geändert von florian (10.03.2021 07:45:28)
#2 08.03.2021 19:15:02
Re: [Solved] Different Background Colours on specific pages
index.php
<body class="p<?php echo PAGE_ID; ?>">
stylesheet
body.p1 {background-color:green;}
body.p23 {background-color:purple;}
etc.
Beitrag geändert von florian (08.03.2021 19:15:18)
losttrip
#3 08.03.2021 22:18:26
losttrip
Thank you so much.  Works as expected.
#4 22.03.2021 21:24:13
losttrip
Is it possible to use something similar within a js file?
I am using fancybox 3 and I need to style the lightbox background colour specific to it's page background colour.  It is semi-transparent by default, but they want it opaque.
The line of code in the fancybox js file is this:
[== JavaScript ==]
<div class="fancybox-bg"></div>
But if I add the page id code to it:
[== JavaScript ==]
<div class="fancybox-bg p<?php echo PAGE_ID; ?>"></div>
the result source code is:
[== HTML ==]
The page_id code is ignored or maybe not recognized?
I hope that makes sense.
#5 23.03.2021 08:38:00
This code is generated through a javascript so you can't write PHP in it, .js files will not be parsed by PHP
But the page_id should also be available as javascript variable PAGE_ID so
[== JavaScript ==]
 baseTpl: '<div class="fancybox-container" role="dialog" tabindex="-1">' +
      '<div class="fancybox-bg p' + PAGE_ID + '"></div>' +
      '<div class="fancybox-inner">' +
will do the trick
florian, losttrip
#6 24.03.2021 12:41:50
losttrip
That worked perfectly bernd.  Thank you so much.
