#1 17.09.2023 17:48:04
losttrip
Fading partial text
I am drawing a blank on whether this functionality might already exist in any WBCE modules.  I was originally thinking minibanner could work, but was mistaken.
I would like the page to load with heading text visible, eg: You are here
Then I would like some of the words to animate (fade out/in) change to: We are here
Then I would like some of the words to animate (fade out/in) change to: Everyone is here
Then repeat infinitely...
I know I've seen this kind of presentation on lots of website, but now that I want to create it, I can't find it anywhere.
I've done some general searching on the web, but am obviously not using the correct search terms, because I am not finding relevant results.
I'm not asking anyone to create something for me.  I just want to know if anyone knows of a current module with this capability.  If not, perhaps you could point me to a search term that might lead me to a place I can learn to do this on my own.
Thanks in advance!
#2 17.09.2023 18:36:34
Re: Fading partial text
A first idea:
Maybe you could abuse the Vegas-Slider by using a blank image for each picture and only fade the text ...
losttrip
#3 17.09.2023 22:10:18
There are some jquery scripts which exactly do what the TO has in mind. No need for a module imho, just a code2 section.
https://www.jqueryscript.net/blog/best- … ation.html
There's even a plain CSS solution.
https://www.cssscript.com/pure-css-text … animation/
losttrip
#4 18.09.2023 15:49:46
losttrip
Thank you both very much for your guidance.  I ended up using a "fading text" script from the site you suggested, Florian.
