Announcement
#1 19.04.2025 15:22:56
tennstar
[gelöst] Fehlermeldung beim öffnen der Admin Seite
Auf meiner Tauchschulen Seite bei bplaced bekomme ich momentan beim öffnen der Admin Seite folgende Fehlermeldung, die auch sofort nach dem löschen wieder angezeigt wird!
2025-04-19T16:12:56+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/logout/
2025-04-19T16:12:56+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/logout/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-19T14:12:56+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
2025-04-19T14:12:56+00:00 [Deprecated] /admin/logout/index.php:[47] from /admin/logout/index.php:[47] exit "exit(): Passing null to parameter #1 ($status) of type string|int is deprecated"
2025-04-19T16:12:56+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/login/index.php
2025-04-19T16:12:56+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/login/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-19T16:13:02+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/login/index.php
2025-04-19T16:13:02+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/login/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-19T14:13:02+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
2025-04-19T16:13:03+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/start/index.php
2025-04-19T16:13:03+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/start/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-19T14:13:03+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
2025-04-19T16:13:03+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/templates/wbce_flat_theme/dashboard/dashboardinfos.php
2025-04-19T16:13:03+02:00 [Deprecated] /framework/initialize.php:[198] from /templates/wbce_flat_theme/dashboard/dashboardinfos.php:[10] "Constant E_STRICT is deprecated"
2025-04-19T16:13:05+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/admintools/
2025-04-19T16:13:05+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/admintools/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-19T14:13:05+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
2025-04-19T16:13:08+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/admintools/tool.php?tool=errorlogger
2025-04-19T16:13:08+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/admintools/tool.php:[13] "Constant E_STRICT is deprecated"
2025-04-19T14:13:08+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated
Das Frontend funktioniert normal.
WBCE 1.6.3
PHP 8.3.20 PHP 8.4
Kann mir bitte einer helfen, ich komme da nicht weiter!
Gruß tennstar
Edit: Angegebene PHP-Version korrigiert -florian
#2 20.04.2025 06:35:16
Re: [gelöst] Fehlermeldung beim öffnen der Admin Seite
Lade den Anhang herunter, entpacke ihn lokal und überschreibe dann die jeweiligen Dateien auf den Server durch die gefixten.
#3 20.04.2025 08:21:25
tennstar
Danke für die schnelle Reaktion!
Leider hat es nicht gewirkt, es kommt nach wie vor eine Fehlermeldung wo ich nicht weiß wohin damit.
2025-04-20T09:17:39+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/pages/index.php
2025-04-20T09:17:39+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/pages/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-20T07:17:39+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
2025-04-20T09:17:41+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/admintools/
2025-04-20T09:17:41+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/admintools/index.php:[13] "Constant E_STRICT is deprecated"
2025-04-20T07:17:41+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
2025-04-20T09:17:44+02:00 [Visitor Request] http://tsu.bplaced.net/atemreglerservice/admin/admintools/tool.php?tool=errorlogger
2025-04-20T09:17:44+02:00 [Deprecated] /framework/initialize.php:[198] from /admin/admintools/tool.php:[13] "Constant E_STRICT is deprecated"
2025-04-20T07:17:44+00:00 [Deprecated] /framework/dbsession.php:[58] from /framework/initialize.php:[221] DbSession->__construct "session_set_save_handler() [function.session-set-save-handler]: Providing individual callbacks instead of an object implementing SessionHandlerInterface is deprecated"
Gruß tennstar
#4 20.04.2025 08:53:55
Slugger
Die suche im Internet meint dazu
1. E_STRICT is deprecated
Ursache:
Die Konstante E_STRICT wurde ab PHP 8.0 endgültig entfernt. In initialize.php (Zeile 198) wird sie aber noch verwendet
2. session_set_save_handler() Callback-Problem
Ursache:
Seit PHP 7.2 und besonders in PHP 8.0+ ist es veraltet, mehrere einzelne Callbacks in session_set_save_handler() zu übergeben. Stattdessen soll man ein Objekt nutzen, das das SessionHandlerInterface implementiert.
Status Projekt 1-4:  OK
#5 20.04.2025 09:26:59
tennstar
Hallo Slugger, Danke für Deine Mühe und Antwort!
Ich bin leider nicht so bewandert, dass ich mit dem was anfangen kann.
Auch das auskommentieren der Zeile 198 bringt keine Lösung.
Nachdem ich jetzt mal alle meine Seiten bei bplaced kontrolliert habe musste ich feststellen, dass alle diese Fehlermeldung aufweisen, scheint also an bplaced zu liegen!
#6 20.04.2025 09:45:19
Slugger
Wenn es sowieso nur Warnungen sind kann man sie auch solange unterdrücken, bis eine neue Version von wbce verfügbar ist und danach wieder zu Kontrolle einschalten. Das erspart dir wenigstens das leeren der logs
#7 20.04.2025 10:01:28
tennstar
kannst Du mir bitte noch sagen wo ich die logs unterdrücken kann?
#8 20.04.2025 10:29:04
Slugger
Hast du es in Zeile 198 schon so probiert:
error_reporting(E_ALL);
Für Nummer 2 habe ich folgendes für die dbsession.php gefunden,
class DbSession implements SessionHandlerInterface {
    public function open($save_path, $name) { /* ... */ }
    public function close() { /* ... */ }
    public function read($id) { /* ... */ }
    public function write($id, $data) { /* ... */ }
    public function destroy($id) { /* ... */ }
    public function gc($maxlifetime) { /* ... */ }
$handler = new DbSession();
session_set_save_handler($handler, true);
Ob das richtig kann ich nicht beurteilen, dazu bin zu weit weg mit der Materie.
Ich kann bis dato nur Quellcode betrachten, leichte Sachen vergleichen und ändern.
#9 20.04.2025 11:11:25
tennstar
Nein habe ich nicht probiert weil ich eigentlich nicht so fit bin wie Du!
Aber ich habe jetzt festgestellt, dass PHP 8.4. eingestellt war, bin jetzt auf 8.3 zurück und die Fehlermeldung wird auf der Seite wo ich probiert habe nicht mehr angezeigt!
Scheint also ein PHP Problem zu sein!
Werd mir Deine Lösung mal anschauen, oder auch vielleicht ein neues WBCE Update abwarten.
Wo schalte ich die Logs denn aus?
Es ist mit Sicherheit die PHP Version 8.4 die ich bei bplaced aufgeschaltet hatte, das Frontec funktioniert, das Backend zeigt den Fehler  sad
werde dann mal auf das nächste Update von WBCE warten!
Danke nochmals für Deine intensiven Bemühungen.
Gruß tennstar
#10 20.04.2025 12:29:05
Slugger
In der Datei, wie oben erwähnt ersetzen.
Florian hatte es mal erwähnt, das es bei php8.4 noch zwickt und bei 8.3 gut ist
Sehe ich das richtig das deine Seite nur unter http erreichbar ist oder gibt es da gerade Schwierigkeiten?
#11 20.04.2025 14:23:11
tennstar
Ist richtig, ist ja auch nur eine Trainings und Vorbereitungsseite und weils ja auch noch kostenlos ist kann man wohl nicht mehr verlangen!
Danke nochmal
#12 20.04.2025 18:13:44
Im obigen Zip fehlte die wichtigste Datei /framework/dbsession.php). Ist jetzt korrigiert.
Ich hatte mich übrigens schon gewundert, dass WBCE 1.6.3 auf einmal mit PHP 8.3 nicht mehr funktionieren sollte.
#13 20.04.2025 18:40:01
tennstar
Danke Florian  thumb_up
