#1 04.09.2025 12:35:50
gawi
Problem with the URL variable
Hello
On a website with WBCE 1.5.2, we use a plugin for an external reservation system. This system was working correctly, but after a change in the reservation system, the script no longer works with WBCE. This system uses a URL as an global variable, and displaying the variable "var URL = WB_URL = 'https://domena.pl'" in the page code causes the script to fail.
Is it possible to remove displaying of CMS variables in the page code, or at least the single line with the URL variable?
Best regards,
Gawi
#2 04.09.2025 12:46:18
Re: Problem with the URL variable
That was fixed three years ago...
https://github.com/WBCE/WBCE_CMS/commit … 6b6692eea9
If there are any reasons for sticking with that outdated version, manually apply the change of that commit to your class.wb.php
#3 04.09.2025 13:13:31
gawi
Thank you very much. it works.
Regards Gawi
