Announcement
#1 15.12.2025 11:26:13
gawi
Problem with Onebyone module
Hello
I'm testing the onebyone module. This is a very good module for creating content divided into blocks but I have one problem with this module:
If I enter a photo from the media directory or a link to a file from the media directory in any wysiwyg block of the module, the absolute URL appears in the database - without changing to {SYSVAR:MEDIA_REL}.
After changing the url, it is necessary to edit all wysiwyg blocks of the onebyone module and insert a new url.
Can this problem be solved?
Regrads
Gawi
#2 15.12.2025 17:11:27
Re: Problem with Onebyone module
confirmed. Try attached fixed version.
#3 16.12.2025 10:55:24
gawi
Hello!
Thank you very much. The module works very well.
Greetings
Gawi
#4 16.12.2025 16:30:56
Thank you.
I forgot the code sections and the before/after sections when replacing the absolute path with the sysvar placeholder.
This is fixed in v 0.11 which is now available in the AOR.
https://addons.wbce.org/pages/addons.ph … m&item=139
And doing so, I added the same feature to the similiar Blockrocker module.
https://addons.wbce.org/pages/addons.ph … m&item=148
giz, byteworker
#5 16.12.2025 19:03:44
gawi
Thank you.
Greetings
#6 17.12.2025 07:00:09
Can i simply update onebyone or blockrocker too?
In my case, i updated an existing installation of blockrocker module (0.4) and the images in blockrocker sections are gone, i must open each section and correct the image path by hand.
#7 17.12.2025 07:41:48
Hm, seltsam, kann ich auf Anhieb nicht bestätigen.
Werden Bilder sowohl im Backend als auch Frontend nicht angezeigt?
Allerdings bleiben bei bestehenden BR-/ObO-Abschnitten die absoluten Pfade eigentlich einfach stehen, sodass dort keine Anpassungen erforderlich sein sollten.
Konkret hatte ich folgende Änderungen vorgenommen:
in der save.php - beim Speichern (!) alle Vorkommnisse von WB_URL.MEDIA_DIR durch {SYSVAR} ersetzen
In der modify.tpl.php und view.tpl.php - alle Vorkommnisse von {SYSVAR} durch WB_URL.MEDIA_DIR ersetzen - das heißt, wo der absolte Pfad steht, passiert nix weiter.
Kannst du mal schauen, ob die WB_URL korrekt ist? Das ist das einzige, was mir jetzt einfällt, woran es möglicherweise liegen könnte. Also http statt https oder Slash am Ende, der da nicht hingehört oder sowas.
#8 17.12.2025 09:28:34
Tatsächlich wurde anstatt dem Pfad zum Bild die {SYSVAR}/media/2025-Kataloge-Preise/01-Adria-Bilder/adria-wohnwagen-01.jpg angezeigt.
Ich kann es gerade nicht mehr richtig reproduzieren.
Nachdem das Problem auftauchte, habe ich ein Backup eingespielt (Panikmodus) und nun isses wie vorher. Aber es ist im Grund eine Standardinstallation, allerdings bei einem Hoster der mir immer wieder Probleme mit seltsamen Configurationen auf dem Windows Server macht. Kann daran liegen.
Ich versuche es erneut auf einer anderen Seite und melde mich dann wieder. Den Blockrocker 0.4 habe ich sehr oft im Einsatz.
#9 17.12.2025 13:10:32
WBCE 1.6.5
PHP 8.3.27
Auf den Seiten mit Blockrocker (jetzt Version 0.6) nur mit Texten läuft es problemlos:
https://www.ivan-fitness.ch/pages/ernae … ratung.php
https://www.ivan-fitness.ch/pages/firmenfitness.php
Auf Seiten, die Blockrocker mit Bildern im Abschnitt enthalten ist essig:
Halt, die Bilder sind es nicht, scheinbar nur wenn ich den Farbbutton im Blockrocker verwende:
https://www.ivan-fitness.ch/pages/leistungen.php
Im Error Viewer steht sowas:
2025-12-17T12:08:49+00:00 [Deprecated] /modules/blockrocker/templates/modify.tpl.php:[273] from /modules/blockrocker/modify.php:[88] "htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated"
2025-12-17T12:08:49+00:00 [Warning] /modules/blockrocker/templates/modify.tpl.php:[270] from /admin/pages/modify.php:[171] "Undefined array key "BGCOLOR""
2025-12-17T12:08:49+00:00 [Warning] /modules/blockrocker/templates/modify.tpl.php:[273] from /admin/pages/modify.php:[171] "Undefined variable $bloro_bg"
Edit: hat das was mit dem Template zu tun? hier im Backend scheint ein Abschnitt zu fehlen
#10 17.12.2025 13:14:44
Rätselhaft.
Kann ich so auf die Schnelle nicht beheben.
Dann schieb erstmal aus der 0.4 die modify.tpl.php view.tpl.php und save.php per FTP hoch. An der DB-Struktur hat sich nichts geändert.
#11 17.12.2025 13:17:21
Danke, ich habe mir wieder das Backup mit der Version 0.4 drübergebügelt, hat jetzt Zeit.
#12 17.12.2025 13:24:00
Ach, jetzt seh ichs. Das Problem tritt auf, wenn mehr als ein Bloro-Abschnitt pro Seite vorkommt. Hatte vergessen, Hilfsfunktionen in function_exists zu kapseln.
byteworker, robo77
#13 17.12.2025 13:34:52
Danke es funktioniert, wie immer zuverlässig und geschmeidig.  thumb_up
#14 18.12.2025 09:30:11
Es klappt leider noch nicht ganz:
Fehlermeldung: Unknown column 'bloro_bg' in 'field list'
Wenn ich im Modul zum Beispiel im Code davor/danach etwas eintrage. Ich verwende die für Zwischenüberschriften.
#15 18.12.2025 09:42:34
bloro_bg (Hintergrundfarbe) ist in 0.5 hinzugekommen und wird eigentlich beim Updaten angefügt.
#16 18.12.2025 15:56:14
Aha, dann liegt es an mir, dass ich die 0.5er übersprungen habe, ich installiere es später nochmal.
#17 18.12.2025 16:49:21
Das zusätzliche Feld wird - zumindest bei meinen Tests - auch beim direkten Update 0.4 -> 0.7 eingefügt.
#18 19.12.2025 07:34:49
Guten Morgen,
ich nerve wirklich ungern, aber ich habe immer noch das Problem.
Testweise eine andere Seite (WBCE 1.6.4) mit Blockrocker auf die aktuelle 0.7 geupdatet. Im Errorlog erscheint das hier:
2025-12-19T06:28:29+00:00 [Warning] /modules/blockrocker/templates/modify.tpl.php:[270] from /admin/pages/modify.php:[167] "Undefined array key "BGCOLOR""
2025-12-19T06:28:29+00:00 [Warning] /modules/blockrocker/templates/modify.tpl.php:[273] from /admin/pages/modify.php:[167] "Undefined variable $bloro_bg"
2025-12-19T06:28:29+00:00 [Deprecated] /modules/blockrocker/templates/modify.tpl.php:[273] from /modules/blockrocker/modify.php:[88] "htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated"
2025-12-19T06:28:58+00:00 [Visitor Request] https://www.mech-meyer.ch/admin/pages/m … page_id=16
Und im Modul, sieht es so aus. Da scheint was zu fehlen, ich kann die Abschnitte bearbeiten aber keine Hintergrundfarbe im Blockrocker angeben.
#19 19.12.2025 07:57:07
Wie aktualisierst du? Über Erweiterungen > Module oder per FTP hochschieben?*
Ich kanns auf Deubel komm raus nicht repoduzieren.
Hier ist als allerletzter Versuch eine 0.8 mit geändertem Upgrademechanismus. Wenns damit auch nicht funktioniert, bin ich raus.
Edit: Die Änderungen greifen natürlich nur, wenn über ERweiterungen > Module geupdatet wird.
byteworker, mk70
#20 19.12.2025 08:49:19
Danke das probiere ich aus. Ich mache das immer über Module installieren, nicht via FTP hochladen. Melde mich später.
#21 19.12.2025 09:00:19
Bitte immer auch Häkchen bei "Überschreibe neuere Dateien" setzen.
#22 19.12.2025 11:31:54
Danke Florian, das hat geklappt!
Jetzt funktioniert es einwandfrei.  thumb_up
