#1 09.06.2026 12:24:43
giz
extcal1.2.14 deprecated meldungen
Hallo zusammen!
kleiner Hinweis:
ExtCal 1.2.14 wirft folgende Meldungen mit WBCE 1.67 und Php 8.4.16
2026-06-09T12:22:43+02:00 [Deprecated] /modules/extcal/SabreDAV/vendor/sabre/http/lib/Client.php:[176] from /modules/extcal/SabreDAV/vendor/composer/ClassLoader.php:[301] Composer\Autoload\includeFile "Sabre\HTTP\Client::sendAsync(): Implicitly marking parameter $success as nullable is deprecated, the explicit nullable type must be used instead"
2026-06-09T12:22:43+02:00 [Deprecated] /modules/extcal/SabreDAV/vendor/sabre/http/lib/Client.php:[176] from /modules/extcal/SabreDAV/vendor/composer/ClassLoader.php:[301] Composer\Autoload\includeFile "Sabre\HTTP\Client::sendAsync(): Implicitly marking parameter $error as nullable is deprecated, the explicit nullable type must be used instead"
2026-06-09T12:22:43+02:00 [Deprecated] /modules/extcal/SabreDAV/vendor/sabre/event/lib/EventEmitterTrait.php:[99] from /modules/extcal/SabreDAV/vendor/composer/ClassLoader.php:[301] Composer\Autoload\includeFile "Sabre\Event\EventEmitterTrait::emit(): Implicitly marking parameter $continueCallBack as nullable is deprecated, the explicit nullable type must be used instead"
2026-06-09T12:22:43+02:00 [Deprecated] /modules/extcal/SabreDAV/vendor/sabre/event/lib/EventEmitterInterface.php:[63] from /modules/extcal/SabreDAV/vendor/composer/ClassLoader.php:[301] Composer\Autoload\includeFile "Sabre\Event\EventEmitterInterface::emit(): Implicitly marking parameter $continueCallBack as nullable is deprecated, the explicit nullable type must be used instead"
2026-06-09T12:22:43+02:00 [Deprecated] /modules/extcal/SabreDAV/vendor/sabre/http/lib/Request.php:[41] from /modules/extcal/SabreDAV/vendor/composer/ClassLoader.php:[301] Composer\Autoload\includeFile "Sabre\HTTP\Request::__construct(): Implicitly marking parameter $headers as nullable is deprecated, the explicit nullable type must be used instead"
2026-06-09T12:22:44+02:00 [Deprecated] /modules/extcal/SabreDAV/vendor/sabre/http/lib/Response.php:[104] from /modules/extcal/SabreDAV/vendor/composer/ClassLoader.php:[301] Composer\Autoload\includeFile "Sabre\HTTP\Response::__construct(): Implicitly marking parameter $headers as nullable is deprecated, the explicit nullable type must be used instead"
Scheint aber soweit alles zu funktionieren....bin aber noch am einrichten von Nextcloud-Kalender.
