Ich habe das Modul hier im Einsatz:
PHP Version: 8.3.32
WBCE: 1.6.8
Socialmedia made easy
Version: 2.11
Irgendwo hängt es mit der internen Suche zusammen. Siehe Errorlog:
2026-07-16T07:58:14+00:00 [Visitor Request] https://www.korloyeurope.eu/search/inde … 90&string=
2026-07-16T07:58:14+00:00 [Deprecated] /modules/socialbaker/include.php:[135] from /templates/keg-1sp-hero/index.php:[169] socialBaker "urlencode(): Passing null to parameter #1 ($string) of type string is deprecated"
2026-07-16T07:58:14+00:00 [Deprecated] /modules/socialbaker/include.php:[137] from /templates/keg-1sp-hero/index.php:[169] socialBaker "str_ireplace(): Passing null to parameter #2 ($replace) of type array|string is deprecated"
Frage: woran kann es liegen?
Viele Grüße Norbert
Beitrag geändert von byteworker (16.07.2026 10:49:20)
Ich habe das Modul Socialmade easy auf die aktuelle Version 2.12 aktualisiert, aber gleiches Problem:
2026-07-16T10:48:31+00:00 [Visitor Request] https://www.korloyeurope.eu/search/inde … tring=2026
2026-07-16T10:48:31+00:00 [Deprecated] /modules/socialbaker/include.php:[135] from /templates/keg-1sp-hero/index.php:[169] socialBaker "urlencode(): Passing null to parameter #1 ($string) of type string is deprecated"
2026-07-16T10:48:31+00:00 [Deprecated] /modules/socialbaker/include.php:[137] from /templates/keg-1sp-hero/index.php:[169] socialBaker "str_ireplace(): Passing null to parameter #2 ($replace) of type array|string is deprecated"
2026-07-16T10:57:39+00:00 [Visitor Request] https://www.korloyeurope.eu/search/inde … 90&string=
2026-07-16T10:57:39+00:00 [Deprecated] /modules/socialbaker/include.php:[135] from /templates/keg-1sp-hero/index.php:[169] socialBaker "urlencode(): Passing null to parameter #1 ($string) of type string is deprecated"
2026-07-16T10:57:39+00:00 [Deprecated] /modules/socialbaker/include.php:[137] from /templates/keg-1sp-hero/index.php:[169] socialBaker "str_ireplace(): Passing null to parameter #2 ($replace) of type array|string is deprecated"
Versuch mal, ob es hilft, was das Elektronengehirn hier vorschlägt:
https://chatgpt.com/share/6a58bf41-7634 … 4ecf0cc182
Der schlaue Kerl! ich bin dummerweise etwas un-schlau, wo soll ich den Code einfügen? in der include.php vor den schliessenden Tag?
Versuch mal mit der angefügten include (in .php zurückumbenennen, austauschen)
mk70, byteworker
Danke, das hat geklappt. Damit ist keine Fehlermeldung mehr aufgelaufen:
Bin immer wieder begeistert, wie Du das schaffst. Hut ab!
Grüße Norbert
mk70, beach
Danke für die Blumen (und die Spende), aber der Dank gebührt chatGPT...
