When you create a new topic you have the option to subscribe to that topic.
If you forget to check that option, is there a way to subscribe afterwards ? (the edit-topic screen does not have that option )
regards,
Rinse
Beitrag geändert von florian (21.08.2026 06:38:35)
forget my question, I already found the answer.
On the bottom of each subject one can subsribe
