#1 16.11.2026 19:22:00
ces-gmbh
Bakery 1.8.9 Deprecated-Meldungen bei Zahlungsmethoden
vielleicht kann mir jemand helfen ohne gleich die ganze Funktion auszuschalten. Aber zumindest keine Fehler Meldungen produziert.
[Deprecated] /modules/bakery/payment_methods/cod/languages/EN.php:[96] from /modules/bakery/modify_payment_methods.php:[101] "Function utf8_encode() is deprecated"
[Deprecated] /modules/bakery/payment_methods/cod/languages/DE.php:[90] from /modules/bakery/modify_payment_methods.php:[106] "Function utf8_encode() is deprecated"
[Deprecated] /modules/bakery/payment_methods/cod/languages/DE.php:[91] from /modules/bakery/modify_payment_methods.php:[106] "Function utf8_encode() is deprecated"
[Deprecated] /modules/bakery/modify_payment_methods.php:[188] from /modules/bakery/modify_payment_methods.php:[188] array_map "stripslashes(): Passing null to parameter #1 ($string) of type string is deprecated"
[Exception] There was an unknown exception: array_map(): Argument #1 ($callback) must be a valid callback or null, function "safe_stripslashes" not found or invalid function name in line (190) of /modules/bakery/modify_payment_methods.php
WBCE 1.6.11 | PHP Version: 8.2.35 | Backery 1.89
Besten Dank vorerst!
LG René
#2 Gestern 08:16:50
Re: Bakery 1.8.9 Deprecated-Meldungen bei Zahlungsmethoden
So, KI hilft:
Zum einen in den Sprachdateien der Zahlungsmethoden (modules/bakery/payment_methods/cod/languages/DE.php etc.) alle Vorkommnisse von
$MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_CUSTOMER'] = utf8_encode($MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_CUSTOMER']);
	$MOD_BAKERY[$payment_method]['EMAIL_BODY_CUSTOMER'] = utf8_encode($MOD_BAKERY[$payment_method]['EMAIL_BODY_CUSTOMER']);
	$MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_SHOP'] = utf8_encode($MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_SHOP']);
	$MOD_BAKERY[$payment_method]['EMAIL_BODY_SHOP'] = utf8_encode($MOD_BAKERY[$payment_method]['EMAIL_BODY_SHOP']);
ersetzen durch
$MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_CUSTOMER'] = mb_convert_encoding($MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_CUSTOMER'], 'UTF-8', 'ISO-8859-1');
$MOD_BAKERY[$payment_method]['EMAIL_BODY_CUSTOMER'] = mb_convert_encoding($MOD_BAKERY[$payment_method]['EMAIL_BODY_CUSTOMER'], 'UTF-8', 'ISO-8859-1');
$MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_SHOP'] = mb_convert_encoding($MOD_BAKERY[$payment_method]['EMAIL_SUBJECT_SHOP'], 'UTF-8', 'ISO-8859-1');
$MOD_BAKERY[$payment_method]['EMAIL_BODY_SHOP'] = mb_convert_encoding($MOD_BAKERY[$payment_method]['EMAIL_BODY_SHOP'], 'UTF-8', 'ISO-8859-1');
In  /modules/bakery/modify_payment_methods.php
$fetch_payment_methods = array_map('stripslashes', $fetch_payment_methods);
ersetzen durch
			fn($value) => is_string($value) ? stripslashes($value) : $value,
Jedoch zu
Das kann ich nicht reproduzieren, im Code von Bakery 1.89 kommt nirgends "safe_stripslashes" vor
Beitrag geändert von florian (Gestern 08:17:33)
#3 Gestern 09:07:45
ces-gmbh
Guten Morgen Florian
"safe_stripslashes" Diesen Bock hatte ich selbst geschossen - natürlich auch durch KI gefunden.
Aber eben, wenn man nicht genau weiss, was zu fragen ist, nützt dies eben auch nicht viel. Es reicht wohl nicht einfach mal die Fehlermeldung durchzugeben.
Besten Dank und "e gfreute" Tag!
LG René
Beitrag geändert von ces-gmbh (Gestern 09:17:16)
#4 Heute 14:53:33
ces-gmbh
Hallo Florian
Es sind wieder neue Fehler aufgetaucht wie folgt:
026-11-17T08:30:22+00:00 [Visitor Request] *https://heilstein-shop.com/modules/bakery/save_item.php*
2026-11-17T08:30:22+00:00 [Deprecated] /modules/bakery/save_item.php:[68] from /modules/bakery/save_item.php:[68] strip_tags "strip_tags(): Passing null to parameter #1 ($string) of type string is deprecated"
2026-11-17T08:30:22+00:00 [Deprecated] /modules/bakery/save_item.php:[69] from /modules/bakery/save_item.php:[69] strip_tags "strip_tags(): Passing null to parameter #1 ($string) of type string is deprecated"
2026-11-17T08:30:22+00:00 [Deprecated] /modules/bakery/save_item.php:[97] from /modules/bakery/save_item.php:[97] strip_tags "strip_tags(): Passing null to parameter #1 ($string) of type string is deprecated"
2026-11-17T14:53:27+00:00 [Visitor Request] https://heilstein-shop.com/armbaender/
2026-11-17T14:53:27+00:00 [Warning] /modules/bakery/view_form.php:[229] from /framework/frontend.functions.php:[461] "Undefined array key 28"
2026-11-17T14:53:27+00:00 [Warning] /modules/bakery/view_form.php:[230] from /framework/frontend.functions.php:[461] "Undefined array key 28"
2026-11-18T08:06:54+00:00 [Visitor Request] https://heilstein-shop.com/action/
2026-11-18T08:06:54+00:00 [Warning] /modules/bakery/view_form.php:[229] from /framework/frontend.functions.php:[461] "Undefined array key 28"
2026-11-18T08:06:54+00:00 [Warning] /modules/bakery/view_form.php:[230] from /framework/frontend.functions.php:[461] "Undefined array key 28"
2026-11-18T08:07:42+00:00 [Visitor Request] https://heilstein-shop.com/action/
2026-11-18T08:07:42+00:00 [Warning] /modules/bakery/view_form.php:[229] from /modules/bakery/view.php:[450] "Undefined array key 28"
2026-11-18T08:07:42+00:00 [Warning] /modules/bakery/view_form.php:[230] from /modules/bakery/view.php:[450] "Undefined array key 28"
Besten Dank im Voraus
LG René
Beitrag geändert von ces-gmbh (Heute 15:00:01)
