Hello
I try to use Fjatselt Megamenu template and I have this problems:
If I use wisywig in Header Block the top slide disappear!!!
If I use wisywig in Big Top Block I see only a small bottom part of text of the content, the other seems to be in background.
There's a solution?
I use WBCE Version: 1.1.9
TIA
I use english because I don't know German ...
The block "header" replaces the slides - and that is what it does.
For "content" (also a picture) you should use block Big Top Content (3)
An i see, there is an error:
templates/fjatselt_megamenu/index.php
[== Undefiniert ==]
if ($page_content_3 != '') {
echo '<div style="clear:both;">'.$page_content_3.'</div>';
?>Add: style="clear:both; padding-top:30px;"
Beitrag geändert von grindbatzn (29.12.2016 19:16:22)
Many thanks, I try this and will say about
