I am trying to copy a document (a newsletter) to show on my website, into a WYSIWYG textbox. The document is 2015 words long but I am only able to copy/paste 1492 words. I am able to enter more text by actually typing in but I can't paste. Is there a limit on the amount of text that can be pasted into a document?
can't reproduce. Do you c/p from Word or from HTML? Are there any images or formattings inside?
Thanks @florian.
I'm copying from a document in LibreOffice. There are images in it but I was just copying the text. There probably is some formatting, I probably need to remove this.
Sorted this. Problem seemed to be related to formatting in LibreOffice. I changed the formatting of the text in LO, then I could copy and paste, then removed formatting in the editor.
You also can use shift + ctrl + v to paste only the text without LO's inline CSS formats.
