Hi. Foldergallery on PHP7.2 gets this message: Fatal error: 'continue' not in the 'loop' or 'switch' context in /modules/foldergallery/scripts/functions.php on line 114. Can you help?
open functions.php with notepad++ or similiar. I guess the code looks like
if (function_exists('getimagesize')) {
list($width, $height, $type, $attr) = getimagesize($file);
continue;
You can try just to remove the else part, e.g. change it to
But there might be more issues, depending on which version of the FG you use.
working thank you!
