#1 19.10.2018 08:54:55
dany3337
Procalendar can't modify anything
Hello community
I have a huge problem
I have on the page http://frauenarth.ch/pages/startseite/f … ogramm.php a procalendar where I have a programm.
In the backend I see everything (See "Frauenarth1") and I can create a new date. But when I click on "Save" then I get to a page called "Save.php" but nothing happens. The same happens when I want to delete a date.
So quick said, I cant modify anything and this is a huge problem. Could someone help me?
I can also send you the access data so that you can look at the problem in the backend.
Thanks for your reply
#2 19.10.2018 08:55:23
dany3337
Re: Procalendar can't modify anything
Here is the image of the save.php file problem
#3 19.10.2018 09:02:47
As I wrote, send me the login and I will have a look.
#4 19.10.2018 13:33:15
Problem is solved, if anyone else has this issue with ProCalendar 1.3.3:
in save.php, change
require(WB_PATH.'/framework/functions.php');
to
require_once(WB_PATH.'/framework/functions.php');
That's all.
thanks
