#1 19.11.2018 02:18:04
meetje
Problems with search
Hoi
(only, I think when searching) on my website (www.welkominnijmegen.nl) I get this message:
Warning:
count(): Parameter must be an array or an object that implements Countable in /home/massagev/public_html/welkominnijmegen.nl/modules/show_menu2/include.php on line 96
and on one of the pages one are send to:
Deprecated: Function create_function() is deprecated in /home/massagev/public_html/welkominnijmegen.nl/framework/frontend.functions.php on line 124
See sceenshots.
What goes wrong and more important: what can be done about it?
WBCE Version: 1.3.2 Tag: 1.3.2 PHP Version: 7.2.10 As far as I remember this wasn't the case before my upgrade a few days ago.
#2 19.11.2018 02:53:33
Re: Problems with search
The warning about count() is a PHP 7.2 problem that is already solved.
Replacing the /modules/show_menu2/include.php with this version should fix it.
Here for reference the german thread about this problem:
https://forum.wbce.org/viewtopic.php?id=2418
For the deprecated message you can - for a first aid - disable the error-reporting in the backend.
freerk55
#3 19.11.2018 13:28:09
meetje
Thank you. Must have been sleeping searching for a solution.
Of course smile it workes after your tips, so thanks a lot!
