There was a snippet "hascontent" on WB that was useful for hiding a block of code when a particular section was not used on a page.
<?php if (hascontent(XXX) == true){ ?>
BLOCK OF HTML TO SHOW OR HIDE
<?php } ?>This was helpful to only show associated CSS when there is content of that type on the page.
Is there something similar available which is compatible with the current version of WBCE?
The snippet is still available, but not compatible with PHP > 5.6, so it's not a WBCE compatibility problem.
But you don't need a snippet.
Instead of <?php page_content(2) ?>, You can either put the following code into your template
ob_start();
page_content(2);
$content = ob_get_contents();
ob_end_clean();
if (strlen($content) > 50) {
Your HTML code goes here...
<?php echo $content; // if needed/wanted here ?>
And/ Or here...
<?php } ?>Or have a look in the newer templates like Buschwerk, how it's done there:
First, all content blocks are fetched:
require_once __DIR__.'/info.php';
foreach($block as $k=>$v){
ob_start();
page_content($k);
$block[$k] = ob_get_clean();
}Then it's simple to check if a block has content:
<?php if ($block[2]!='') { ?>
<?php echo $block[2]; // if needed/wanted here ?>
and/or here...
<?php } ?>Offline
losttrip
Can someone please give me a link to (or send me) the "hascontent" snippet.
Would like to have a look into it.
Think such a (working) snippet would be helpful especially for users that are not that fit in php.
Here you are
(Attachment removed - florian)
Beitrag geändert von florian (23.02.2019 08:54:13)
Ich habe es jetzt nicht geprüft, aber der Code unten könnte es tun:
function hascontent($iBlockID) {
global $database;
$sSqlf = "SELECT COUNT(section_id) FROM `{TP}sections` WHERE `block` = %d AND `page_id` = %d";
$count = $database->get_one(sprintf($sSqlf, (int) $iBlockID, PAGE_ID));
return ($count != false) ? true : false;
}Wobei ich würde den Funktionsnamen irgendwie sprechender gestalten, sowas wie
block_has_content($iBlockID) oder
has_block_content($iBlockID)
Beitrag geändert von stefanek (22.02.2019 21:25:39)
losttrip
Wollte ich grade schreiben,
nach einem ersten schnellen Blick ist das "hascontent" eigentlich total irreführend wie die übergebene $section_ID (das ist eine Block_ID).
Es wird nicht geprüft ob ein Block Inhalt hat sondern ob ein Block auf der Seite vorhanden ist.
Wenn also ein Block vorhanden ist und (warum auch immer) keinen Inhalt hat ist hascontent trotzdem true.
Christians Schnippsel funktioniert wenn man die letzte Zeile korrigiert ;-)
return ($count != false) ? true : false; ... nein in Europa verwenden wir beim Programmieren nicht € statt $ ...
Ja, sollte natürlich false sein...
Danke Bernd.
Übrigens, warum frage ich überhaupt ab, ob $count nicht false ist?
Der Hintergrund ist der, dass die Methode $database->get_one() immer false zurück gibt, wenn es kein Ergebnis gibt, sprich keine Daten bei der Query ermittelt werden konnten.
Und in diesem Fall ist es auch alles, was wir wissen wollen, gibt es Rückgabewerte (true) oder gibt es sie eben nicht (false).
Beitrag geändert von stefanek (22.02.2019 20:22:11)
please write in english to give the TO the chance to follow the discussion.
Sorry,
the snippet Christian posted is working with the corrected last line see post #6.
But the initial name "hascontent" is totaly misleading, also the so called variable $section_ID (should be $block_ID) :
The snippet simply checks if there is a block on a page, it does not check if this block has any content.
I can make later this evening a new snippet with Christians content, but would prefer to call it something like "pageHasBlock" ...
Yes, it actually does.
It checks if the block has any section (section_id) associated with it on the page (PAGE_ID). And if it is the case the function returns TRUE.
Regards,
Beitrag geändert von stefanek (22.02.2019 21:20:58)
No need to apologize. I read this forum with Google Translate on, so I didn't even realize that your posts were not written in English.
@Christian - Thank you for taking the time to look into and re-work the snippet. Much appreciated!
@florian - thank you for your solutions. Are those methods "better" in some way than the "hascontent" or Christian's reworking? Or are those simply different ways of achieving the same result? I ask because, it was just always so easy for me to remember how to add the "hascontent" code to my templates, but if it is not the best method, I will evolve.
@bernd - I realize the name "hascontent" is misleading, but I always knew what the snippet did, and I missed it's ease of use and functionality. I agree a more appropriate name would be beneficial moving forward.
Thank you all for your participation!
stefanek, bernd
Hello losttrip,
I prepared a new snippet module with this function and attach it to this post.
I expanded the code a little bit and renamed the function name for it to be less confusing and phrased it in a way that it poses as a question "Has Block Content?"
So the new function name is:
Enjoy.
And I think it could be also uploaded to the Addon Repository.
I'm not Florian, but from my perspective both ways are legit.
There is some benefit in using it the way Florian proposes.
You don't need the snippet/module to be present on the installation for the template to work. This is one benefit.
Another benefit might be that you can do some processing on the content of the block if you need to, because the content of the block is now in the variable , let's say $block[2].
For example you could run a str_replace operation on it like so:
$block[2] = str_replace('h1>', 'h2>', $block[2]);
and doing so replace all erronously placed <h1></h1> headings with h2 headings.
But generally if you have been doing good using the function up till now, you just can keep it as a working solution and if you need more you can always come back and use Florians suggestions.
Hope this helps to see the different solutions in a better perspective.
Regards,
(Attachment removed, newer version below - florian)
Beitrag geändert von florian (23.02.2019 08:55:05)
bernd, losttrip
Thank you for doing this.
I installed the module (snippet). On page load, I get a white screen with this error:
Parse error: syntax error, unexpected '==' (T_IS_EQUAL), expecting ')' in /home/.../modules/has_block_content/include.php on line 10I get this error even without any calling code in my template index.php file.
Beitrag geändert von losttrip (23.02.2019 05:54:58)
Here's the working one, there was just one '=' too much.
Available at AOR too: https://addons.wbce.org/pages/addons.ph … m&item=108
Please note: even if there's an empty section the snippet returns true.
Beitrag geändert von florian (23.02.2019 08:55:39)
losttrip
Thank you! Working perfectly now.
Beitrag geändert von losttrip (23.02.2019 07:11:40)
@Florian
Thank you for uploading the Snippet to the AOR.
I attach a new version (0.0.2) of has_block_content.
The calls are the same
has_block_content(YOUR_BLOCK_ID)
but it now actually checks for CONTENT if a section or sections are present in that block on that page.
It now will only return TRUE if there actually is any content. (At least it works with WYSIWYG, I didn't check any other modules).
It will also consider the Publication Time (publ_start and publ_end), so if the section is not public it will return FALSE.
The new function code is:
* @platform WBCE CMS
* @license GNU/GPL v.2
* @copyright Christian M. Stefan
* @brief Check if a templates layout block has any content (section) in it.
* @global object $database
* @global object $wb
* @global array $globals several global vars
* @global array $TEXT
* @global array $MENU
* @global array $HEADING
* @global array $MESSAGE
* @param integer $iBlockID The ID of the layout block of the template
* @return bool true if has content, else returns false
function has_block_content($iBlockID = NULL) {
global $database;
$sBlockContents = '';
if ($iBlockID != NULL) {
$count = $GLOBALS['database']->get_one(sprintf($sSqlf, (int) $iBlockID, PAGE_ID));
if ($count != false){
$sSqlf = "SELECT `section_id`, `module`, `publ_end`, `publ_start` FROM `{TP}sections` WHERE `block` = %d AND `page_id` = %d";
if ($rSections = $database->query(sprintf($sSqlf, (int) $iBlockID, PAGE_ID))){
if ($rSections->numRows() > 0){
while ($aSection = $rSections->fetchRow(MYSQL_ASSOC)) {
// skip this section if it is out of publication date
$now = time();
if (!(
($now <= $aSection['publ_end'] || $aSection['publ_end'] == 0)
($now >= $aSection['publ_start'] || $aSection['publ_start'] == 0)
continue;
// check if module exists
$sModuleViewFile = WB_PATH . '/modules/' . $aSection['module'] . '/view.php';
if (is_readable($sModuleViewFile)) {
ob_start();
$page_id = PAGE_ID;
$section_id = $aSection['section_id'];
// we need those global vars to correctly operate the view.php
global $database, $wb, $globals, $TEXT, $MENU, $HEADING, $MESSAGE;
$admin = $wb;
if (isset($globals) and is_array($globals)) {
foreach ($globals as $sGlobalName) {
global $$sGlobalName;
require $sModuleViewFile; // fetch content using the view.php
$sSectionContent = ob_get_clean();
if($sSectionContent != ''){
$sBlockContents .= '~';
unset($sSectionContent);
return ($sBlockContents == '') ? false : true;
}Have fun.
P.S.
@losttrip, please check if it works for you. You just can upgrade it via addons/modules
P.P.S
Since this is a very new module with a very new code, I removed the Author of "hascontent" snippet in the info.php
Beitrag geändert von stefanek (23.02.2019 08:13:56)
losttrip
Thank you, I've updated the AOR.
Btw, I think it would be better if the versioning starts with 0.1 and so on and not 0.0.1, 0.0.2...
And for $module_platform, please use 1.3 (the given platform version is the version of the other™ CMS - in which the snippet probably won't work)
Beitrag geändert von florian (23.02.2019 08:56:23)
Hello Florian,
feel free to adjust the variables in the info.php to your liking.
The Snippet could work easily with WebsiteBaker CMS with a little change, but I don't care too much about this other CMS (or actually not at all, to be honest).
