Hi
I use WBCE 1.4. on WAMP with PFP 7.0.10.
When adding page of Menu Link type following warning appears:
Warning: strpos(): Empty needle in D:\WAMP\www\....\modules\menu_link\modify.php on line 107
Menu link is created and everything is working correctly despite the warning that appears during adding link.
Is there something in the code of menu link module that can be corrected?
Regards
Gawi
I can't reprocuce this error. I guess it appears only on local testing environments, not on real live webservers.
It does not appear on real serwer. But on live webserwer warnings are hidden.
Gawi
Not necessary. I have activated at settings > advanced options > php error reporting to "Show all errors" (and that online testing environement is able to show warnings and errors an does not suppress them), and I still don't get that warning. I also tried at general settings disabling manage sections / section blocks, set the section-anchor string to empty string and decreased PHP to 7.0.32 (the lowest version available), but still no warning appears.
The strange thing about the warning: Line 107 reads
if (strpos($aData['anchor'], SEC_ANCHOR) !== false){and the needle is the constant SEC_ANCHOR. But why can it be empty ln some cases?
Beitrag geändert von florian (07.10.2019 00:46:58)
Hm ...
error confirmed - WBCE 1.4.0 - MAMP PHP 7.3.8 (xd 2.7.2) - local ...
The problem is that SEC_ANCHOR holds an empty string ("") ...
and in the "line 107" we/you are trying to find an empty string inside a given source
so - a quick one/fix could be
File: ~/modules/menu_link/modify.php
Line: ~107
if ((SEC_ANCHOR!="") && (strpos($aData['anchor'], SEC_ANCHOR) !== false)){to test also if the SEC_ANCHOR is "empty" ...
kind regards
Kant
Sapere aude!
Thank you. It works. No warnings!
Gawi
Now fixed on GitHub.
