#1 06.10.2019 14:50:53
gawi
show_menu2 breadcrumb
Hi
I have problem with breadcrumb displaing (WBCE1.4)
In the template I use following code for beradcrumb:
<p class="breadcrumb">
                    <a href="<?php echo WB_URL; ?>">
                      <i class="icon-home" aria-hidden="true"></i></a> /
                    <?php show_menu2(0, SM2_ROOT+1, SM2_ALL, SM2_CRUMB, '<span class="[class]"> / [a][menu_title]</a></span>', '', '', '', '<span class="[class]">[a][menu_title]</a></span>');?>
</p>
As a result the following html code is created:
      <a href="http://localhost:3000/mysite">
      <span class="menu-expand menu-parent menu-first">
        <a href="http://localhost:3000/mysite/pl/page.php" target="_top" title="Page">Page</a>
      </span>
      <span class="menu-current"> /
        <a href="http://localhost:3000/mysite/pl/page/subpage.php" target="_top" title="Subpage">Subpage</a>
      </span>
      </span>
    </p>
At the end of breadcrumb additional </span> closing tag is added and HTML validator shows error.
Can you help me to find what what is wrong with the breadcrumb code?
Best Regards
Gawi
#2 06.10.2019 16:17:05
Re: show_menu2 breadcrumb
Not sure if this is the reason, but in your SM2 call the last parameter is missing, try it this way:
show_menu2(0, SM2_ROOT+1, SM2_ALL, SM2_CRUMB, '<span class="[class]"> / [a][menu_title]</a></span>', '', '', '', '<span class="[class]">[a][menu_title]</a></span>',false);
#3 06.10.2019 16:45:27
gawi
Thank you for answer. Unfortunately it did not helped. Still additional </span> is added at the and.
Regards Gawi
#4 06.10.2019 17:12:44
Hi gawi,
i have checked bernds code and there are no too many span elements, so the span element must be in your template.
#5 06.10.2019 18:22:39
gawi
ok. Thank you. I will for fault.
Regards
Gawi
#6 06.10.2019 18:32:18
Can you display the whole code from the index.php of your template?
#7 06.10.2019 19:36:46
gawi
I found my error.
I use breadcrumb code in two places in my template. When I corrected code in both places according to you suggestion everything it is ok.
<?php show_menu2(0, SM2_ROOT+1, SM2_ALL, SM2_CRUMB, '<span class="[class]"> / [a][menu_title]</a></span>', '', '', '', '<span class="[class]">[a][menu_title]</a></span>',false);?>
Thank you for help.
Best Regards
Gawi
