#1 04.03.2020 17:24:18
losttrip
Show sidebar on page if it is included in GlobalBlock array
I have a site which uses the "has_block_content" snippet to hide the sidebar if there is no section appointed to "block 2".
<?php if (has_block_content(2)) { ?>
    <div class="sidebar">
        <?php globalBlock(17, true, true, array(6,12,24,25,26,27) ); ?>
        <?php page_content(2); ?>
<?php } ?>
As you might notice, I am also trying to use the globalblock module to show section 17 on select pages.  I'm eventually going to have multiple global block entries for different sections on dozens of pages.
The problem is, most of the pages where I want the globalblock to appear do not have any Block 2 content... so the sidebar does not appear, and therefore the globalblock section content does not appear.
Is there a way to check for "has_block_content" AND to see if the page is in the globalblock array?
I know another option is to add a section picker to every page, but there are dozens of pages, so I was trying to find a more economical solution.
Any help would be appreciated.
#2 04.03.2020 17:35:22
Re: Show sidebar on page if it is included in GlobalBlock array
I guess it could work to buffer the output, put it together in one variable and then write it on the page, something like
ob_start();
page_content(2);
$content = ob_get_contents();
ob_end_clean();
if (strlen($content) > 50) {
  echo '<div class="sidebar">';
  echo $content;
  echo '</div>';
#3 04.03.2020 18:10:38
losttrip
You're the best!  Thanks for giving me the inspiration I needed to put the pieces together.
Since the globalBlock module already has buffering capabilities, I implemented the following:
<?php $buffer = globalBlock ( 17, true, true, "6,12,24,25,26,27"  ); ?>
<?php if (has_block_content(2) || (strlen($buffer) > 50)) { ?>
        <?php echo $buffer; ?>
<?php } ?>
Thank you again!
