#1 20.06.2020 11:40:44
keepshango
[solved] Module to allow comments on page bottom ?
Hi,
*** MY CONFIGURATION ***
PHP 7.2.24
WBCE CMS 1.4.3 :
TEMPLATE : Acoudesz
I have been searching for a comment module, but the AOR search only leads to this page (removed modules) :
https://addons.wbce.org/pages/addons.ph … tem_id=135
*** Qs ***
Haven’t these modules being replaced by some new others ?
Can you make recommandation for embeddable solutions (with Code2) ?
May the “OneForAll“ module do the job for a simple comment section on page bottom ?
I know “IntenseDebate“ but it may be outdated !
Regards
#2 20.06.2020 12:14:58
Re: [solved] Module to allow comments on page bottom ?
OneForAll is not suitable for this, the module has a completely other scope.
I think it should work with IntenseDebate, they provide a JS snippet which you have to put into a code2 section. But the comments are hosted on a third party platform then and I don't know if that service is GDPR compliant (assuming you are living in Europe and addressing EU based audience).
To host the comments on your own site:
a) There is the module "Reviews and Ratings", which can also be used as a comment module (see examples on the module's homepage).
b) Or you can give the module "Feedback" a try, it seems to be similiar to the module "global comments" which is no longer available as you correctly noticed. The module is available in the Add-on repository of our competitors, but should work with WBCE too.
#3 20.06.2020 13:24:24
keepshango
Thank U  smile
