#1 21.06.2020 10:15:10
keepshango
Need clearer info upon “One by one“ module usability
Hi,
*** MY CONFIGURATION ***
PHP 7.2.24
WBCE CMS 1.4.3
TEMPLATE : Acourdesz
My home page main block actually contains two text paragraphs between which I wish to insert 2 images to be standing side by side with their respective short description text. I can get this done using CKEditor but the process (and result) to have images and text descriptions framed together, is not efficient enough.
It also seems that I may not use the “One by one“ module in this purpose, because its outputs depends on related pages and IDs,, so that it does not allow the outputs to be inserted in another page (my home page).
But maybe I misunderstand how this module may be used !
Can you please help me to choose the most appropriated way to do what I expect to, having in mind that I also consider to add some hover effects on images ?
Regards
#2 21.06.2020 11:25:44
Re: Need clearer info upon “One by one“ module usability
Yes, there probably is a misunderstandment.
- Just install the One by one module,
- create an ObO section on your homepage,
- set the display mode to 50:50
- and insert the desired content into the first both WYSIWYG editor tabs of the ObO section.
- Save and you're done.
