WBCE Version: 1.5.0
Day: 1.5.0
PHP Version: 7.4.22
News with Images ver 5.0.7
Just an FYI
If I add a preview image to a post, and then delete it later, the teaserpic div with the link and a blank img source remains behind. This displays as additional space of one blank line on the front end.
<div class="mod_nwi_teaserpic">
<a href="https://www.mysite.com/posts/welcome-21/"><img src=""></a>
</div>Beitrag geändert von losttrip (06.09.2021 06:38:56)
This is the default output if a post has no teaser image, it also appears if a post is published without having a preview image (eg it has not to be deleted). It's the wanted behaviour. To avoid this:
find in /modules/news_img/functions.inc.php
$post_img = "<img src='".WB_URL."/modules/news_img/images/nopic.png' alt='empty placeholder' style='width:".$previewwidth."px;' />";and change it to
$post_img = "";Offline
losttrip
Thank you for your explanation.
I have to apologize, I just realized it is the output of a NIA code section which is showing this behaviour. And it's not because of a deleted Preview image. It has to do with the NIA display code, when there is a Long Description (or Gallery).
The code for posts with a Long Description display:
</div>Which creates a blank vertical space.
Where as those without a long description dsiplay:
</div>And there is no space added.
I hope this clears up my issue. I am sure if has to do with the NIA code below.
{% if (news.CONTENT_LONG or news.HASGALLERYIMAGES) %}
<a href="{{ news.LINK }}">{% endif %}<img src="{{ news.IMAGE }}" />{% if (news.CONTENT_LONG or news.HASGALLERYIMAGES) %}</a>{% endif %}
I added the if statements for the link because I did not want to have the cursor: no-drop behaviour on preview images when there was no long content.
This is the full code of the display mode.
<div class="mod_nia">
<h2 class="latest_news">{{ lang.TXT_HEADER }}</h2>
{% for news in newsItems %}
{% if news.TS_POSTED_WHEN > 0 %}
<div class="mod_nwi_group">
<div class="mod_nwi_teasertext">
<h3>{{ news.TITLE }}</h3>
<div class="mod_nwi_metadata"><!--{{ news.DISPLAY_NAME }} | -->{{ news.TS_PUBLISHED_WHEN | date(lang.DATE_FORMAT) }}</div>
{{ news.GROUP_IMAGE }}
<div class="mod_nwi_shorttext">
{{ news.CONTENT_SHORT}}
<a href="{{ news.LINK }}">{{ lang.TXT_READMORE }}</a>
{% endif %}
<div class="mod_nwi_spacer"><hr /></div>
{% endif %}
{% else %}
{{ lang.TXT_NO_NEWS }}
{% endfor %}
</div>Beitrag geändert von losttrip (09.09.2021 00:10:57)
The no-drop cursor
NWI: functions.inc.php, remove "style="cursor:no-drop;'" from l. 1169 & 2226
if ( (strlen($post['content_long']) < 9) && ($anz_post_img < 1)) {
$post['post_link'] = '#" onclick="javascript:void(0);return false;" style="cursor:no-drop;';
}NIA does afaik not create a no-drop cursor.
losttrip
Thank you for your help.
Sorry for the slow reply. For some reason I get email notifications for replies to some (not all) of my thread days later.
I implemented your suggestions from #2 and #4 and that achieved our desired effect, THANK YOU!
PLEASE IGNORE THE FOLLOWING. I think I have confused the issue. I will respond, if/when I need more help.
Thank you again!
IGNORE...
I still a related issue I need to resolve. I have css code for link tags (border shadow etc.), so even though the cursor doesn't change on hover of the "non-link" the image styles still activate, which is confusing, since there is no link. Sorry, if this is confusing. I have a NWI section, and I would like to implement the same sort of IF statement to only show the Link code IF there is a Long Description or a Gallery in the Loop code below:
<a class="news_img_teaserpic" href="[LINK]">[IMAGE]</a>
</div>This was solved in NIA sections by implementing this code, which only outputs the link code IF Long Description has content or a Gallery:
Beitrag geändert von losttrip (09.09.2021 00:40:00)
