#1 11.09.2021 22:37:24
losttrip
[solved] modify ckeditor default table width
By default, all tables have a width of 500 (500px), which is an inline style.
I would like to change the default (e.g., 100% ), or have no value set as the default.  That way I can control the table widths with CSS (without having to use !important hacks).
I found this code on several sites, so I added it to the end of my /editor/wb_ckconfig.js file.  Cleared cache, shutdown browser, and still "500" is used as the default.
CKEDITOR.on( 'dialogDefinition', function( ev ) {
    // Take the dialog name and its definition from the event data.
    var dialogName = ev.data.name;
    var dialogDefinition = ev.data.definition;
    // Check if the definition is from the dialog we're
    // interested in (the "Table" dialog).
    if ( dialogName == 'table' ) {
        // Get a reference to the "Table Info" tab.
        var infoTab = dialogDefinition.getContents( 'info' );
        txtWidth = infoTab.get( 'txtWidth' );
        txtWidth['default'] = '100%';
Any suggestions.
#2 12.09.2021 01:16:19
losttrip
Re: [solved] modify ckeditor default table width
Found it!  Adding this to wb_ckconfig.js worked:
CKEDITOR.on('dialogDefinition', function( ev ) {
      var diagName = ev.data.name;
      var diagDefn = ev.data.definition;
      if(diagName === 'table') {
        var infoTab = diagDefn.getContents('info');
        var width = infoTab.get('txtWidth');
        width['default'] = "100%";
Because I do not want anything set as the default Table Width, I adjusted to:
        width['default'] = "";
