#1 20.10.2021 02:46:57
losttrip
OFA OneForAll style text depending on switch state
WBCE Version: 1.5.0
PHP Version: 7.4.23
OFA 1.1.6 (renamed - hrhshop)
Is there a way to style (text colour) the displayed text based on the state of a switch field?
When the switch is set to "off" (default), the resulting text "In Stock" is displayed in the default font colour (black).  When the switch is turned to "on", I would like the text "Currently Out of Stock" displayed in Red.
Here is the field settings:
The Switch is field_id 2:
This is the "mod_hrhshop_item_fields" table showing the value for field_id 2:
a:2:{i:0;s:0:"";i:1;s:1:"1";}
This is the page setting (Overview (Item-Loop)) for the switch display:
<div class="shop_item_stock">[IN_STOCK]</div>
#2 20.10.2021 08:06:52
Re: OFA OneForAll style text depending on switch state
This can be done with a droplet.
Create a droplet named "stock" and the following code:
if (!isset($s)) {$s='';}
if (stripos($s,"out of") != false) {
	return '<span style="color:red">'.$s.'</span>';
	return $s;
In the OfA field template for the switch, replace
[CUSTOM_CONTENT]
with
[[stock?s=[CUSTOM_CONTENT]]]
losttrip
#3 20.10.2021 11:44:24
losttrip
Thank you so much.  This works perfectly, and it opens my mind to other possibilities using droplets!
