#1 10.02.2022 13:12:42
dev4me
MiniSlides - replacement for MiniSlider
Hello community,
I just released v 1.0 of my new MiniSlides module.
It is meant to be a replacement for the old MiniSlider module.
Download: https://dev4me.com/modules-snippets/ope … inislides/
Demo's: https://dev4me.com/modules-snippets/ope … ides/demo/
Have fun with it.
byteworker, berny, florian, giz, jean
#2 10.02.2022 14:10:14
Re: MiniSlides - replacement for MiniSlider
Bam! a good new module. Thank's a lot for that.
#3 10.02.2022 17:55:41
#4 11.02.2022 17:58:28
dev4me
Just upgraded the minislides module to v1.0.1
There was a problem when the aspect ratio for cropping was set to "none". This is fixed now.
#5 18.03.2022 10:25:43
giz
Hi and thx for the new module.
As it is meant to be a replacement for the old MiniSlider module, will there be the option to add links either in description or/and images some day?
#6 18.03.2022 12:11:04
dev4me
Checkout v1.0.2 > https://dev4me.com/modules-snippets/ope … inislides/
It now allows the use of html in the caption.
It can be used for links, but with a little effort also for images/animations/etc..
byteworker, giz, losttrip
#7 18.03.2022 15:32:52
giz
thumb_up
thank you for this new version with link enhancement
#8 23.01.2023 09:47:30
Short Question to the Caption of this slider. If I insert a text as a caption, I can't change it afterwards. I have to upload a completely new image with a different name, and only then is the text gone.
Is there a way to change the image description / caption text and using the same image?
#9 23.01.2023 10:03:57
Can't confirm, when clicking on the small edit button the modal window opens and I can change the caption. There's a small design glitch on flat BE theme, but changing the caption still works. Does ist look like this at you too?
Beitrag geändert von florian (23.01.2023 10:04:45)
#10 23.01.2023 11:07:45
Same here, but when you try to change or delete the text, is still there in the same place.
I can't remove or delete the text! I can only change the text if I remove the whole image and upload it again under a new name.
#11 23.01.2023 11:10:02
WBCE Version: 1.5.4
PHP Version: 7.4.33
MiniSlides Version 1.0.1
The only way to change/delete the caption text is manually with Adminer.
Ok after a test with MiniSlides 1.0.3 same for me.
Beitrag geändert von byteworker (23.01.2023 11:16:28)
#12 23.01.2023 11:14:26
Might need an update... v 1.0.3 is available.
You can remove the caption by entering - (hyphen) and save.
#13 23.01.2023 11:19:33
- and save.
Fine, this works for me. Thank you florian.
