hello,
I'm using your add-on on my wbce system, and want to ask how i add support using other languages like hebrew,
when i write every where, only at OneForAll add-on i got only ???? (question marks)
i don't know much php or javascripts so i don't know how to deal with it.
i would happy if someone can help me with that.
other parts on wbce deal fine with hebrew..
thanks!
Does this problem appear in the backend or in the frontend of your website?
At settings > show advanced settings > charset, which charset is selected?
thanks for your quick answer..
in settings is on UTF-8, i tried to change it to HEBREW but it doesnt help.
but as i said before, other parts on wbce system works well with hebrew, it olny the part of OneForAll (in frontend and backend)
I see the problem - I've tested it with some hebrew characters, but they're indeed transformed to question marks. But they're not accepted in other modules as well (when I'm trying to create a new page with a hebrew title, there appears a warning "please enter a title", and in wysiwyg the characters are completely erased). Changing the charset in the settings to hebrew, even changing the data base / table charset does not help either.
I have no idea or solution for this issue, I'm sorry.
thank you anyway... !
I can reproduce this problem and think I found the reason for this behavior:
If in the database the collation is "latin1_xxxxx" then the text will be saved as "??????" if I change it to "utf8_unicode_ci" the hebrew characters are saved correctly.
That would also explain why e.g. WYSIWYG pages works correct and some modules don't.
! It's not enough to change the collation for the affected table, the collation must also changed for the paticular fields !
@florian:
could you please check and/or confirm this observation?
You're right, that does the trick.
@eidoil32: Use a database editor like PhpMyAdmin or Adminer to switch the collation of the whole database and the mod_oneforall_...-fields to utf8_unicode_ci to solve the issue.
