#1 04.03.2017 12:59:10
freesbee
Module OneForAll
New Version of OneForAll:
VERSION 1.0.5 (03/03/2017)
VERSION HISTORY
  • Fixed warning in PHP 7.1 about a non-numeric value (reported by dbs)
  • Fixed undefined index when group_id is empty
DOWNLOAD
Download the zip from this download link.
Christoph
florian, grindbatzn, thanks, stefanek
#2 04.03.2017 14:50:05
cwsoft
Re: Module OneForAll
Merci vielmal
#3 23.03.2017 17:16:44
screamindan
Hallo. Hab das grad installiert. Field settings gibt es irgendwie nicht...  sad
#4 23.03.2017 17:20:52
Die sieht als Default-Einstellung nur der Superadmin (ID = 1).
Du kannst das in der  /modules/oneforall/config.php ändern, in dem Du
$settings_admin_only = true;
auf
$settings_admin_only = false;
änderst.
#5 05.04.2017 08:18:55
freesbee
VERSION 1.0.6 (04/05/2017)
VERSION HISTORY
  • Added Dutch language file (thanks to CodeALot)
  • Bugfix: Using multiple fields of type wb_link the select options representing the wb page tree have been multiplied with each new field (reported by astricia)
  • Defining a field type oneforall_link now it is possible to enter either the module directory name as well as the module name as initially defined in the info.php
  • Added more checks to verify that the entered module name is a oneforall module
DOWNLOAD
Christoph
Beitrag geändert von freesbee (30.05.2017 10:21:45)
florian, berny, grindbatzn
#6 30.05.2017 10:19:03
freesbee
VERSION 1.0.7 (05/30/2017)
VERSION HISTORY
  • Added check to see if there is already a media directory using the module name.
    Can cause problems when deleting the module (reported by sky writer, thanks to CodeALot)
  • Bugfix: For items without access file the field link is empty and hence the page access file will be deleted instead of the item access file (reported by dbs, thanks to Ruud)
DOWNLOAD
Christoph
Beitrag geändert von freesbee (30.05.2017 10:22:11)
#7 12.09.2017 18:49:17
freesbee
VERSION 1.0.8 (09/12/2017)
PLEASE NOTE:
After upgrading to this version and resaving an item the url of the item can be changed (droped item_id).
VERSION HISTORY
  • [upload.php] Changed require() to require_once() for file framework/functions.php (thanks to Norbert Heimsath)
  • [save_item.php] Changed require() to require_once() for file framework/functions.php (thanks to Norbert Heimsath)
  • [resize_img.php] Added better support for images taken on mobile devices using exif data 'orientation' (thanks to Ruud)
  • [save_item.php] Changed the way of item filename creation. The item_id is no longer used unless two names are identical (thanks to Ruud)
  • [save_item.php] Removed code for image handling - not concerning duplicating items! (thanks to Ruud)
DOWNLOAD
Christoph
florian, colinax
#8 01.12.2018 09:44:48
VERSION 1.0.9 (11/29/2018) by freesbee
VERSION HISTORY
  • Added params flags and encoding to the function html_entity_decode()
  • Updated Lightbox2 to v2.9.0 (responsive slideshow)
  • Fixed false item link saved into database if item titles are the very same
DOWNLOAD
Download available in WBCE-AOR
#9 20.06.2020 21:32:35
freesbee
VERSION 1.1.5 (06/20/2020)
VERSION HISTORY
  • JSON export / import of fields, page settings and general settings. On export only the page settings of the current SectionID is used, that is the page that has initiated the export. On import the page settings are used for the target SectionID, that is the page that has initiated the import. If you want to use the imported page settings on other pages as well, they must be re-saved in the module "Page Settings" with the appropriate saving options like "this" / "all" / "selected".
  • Added new backend page general settings. During upgrade existing settings in config.php are moved to the new db table mod_oneforall_general_settings and config.php file is deleted.
  • Changed permission to edit module settings from user superadmin (USER_ID == 1) to admin group (GROUP_ID == 1). The setting buttons are only displayed if a user makes part of the admin group.
DOWNLOAD
Download attached to this post .
Christoph
Beitrag geändert von freesbee (20.06.2020 21:43:25)
#10 20.06.2020 21:38:42
freesbee
Neue OneForAll Version:
VERSION 1.1.5 (20.06.2020)
VERSIONSGESCHICHTE
  • Es wurde ein JSON-Export / -Import von Feldern, Seiteneinstellungen und allgemeinen Einstellungen hinzugefügt. Beim Export der Seiteneinstellungen wird die SectionID jenes Abschnitts verwendet, der den Export initiiert hat. Desgleichen wird beim Import der Seiteneinstellungen die SectionID jenes Abschnitts verwendet, der den Import initiiert hat. Falls die importierten Seiteneinstellungen auch auf andere Seiten angewendet werden sollen, müssen diese in den "Seiten Einstellungen" mit den entsprechenden  Übernahmeoptionen "diese" / "alle" / "ausgewählte" nochmals gespeichert werden.
  • Die Rechte zum Bearbeiten der Modul-Einstellungen wurden vom Benutzer Superadmin (USER_ID == 1) zur Administratorgruppe (GROUP_ID == 1) geändert. Die Einstellungsbuttons werden nur angezeigt, wenn der Benutzer Teil der Administratorgruppe ist.
  • Im Backend wurden allgemeine Einstellungen hinzugefügt. Während des Upgrades werden die in der Datei config.php vorhandenen Einstellungen in die neue Datenbank-Tabelle mod_oneforall_general_settings verschoben und die Datei config.php wird gelöscht.
DOWNLOAD
Siehe Anhang im oben stehenden englischen Beitrag.
Christoph
Beitrag geändert von freesbee (20.06.2020 21:45:53)
florian, Slugger, byteworker
#11 20.06.2020 22:13:28
Download ist jetzt auch im AOR aktualisiert
