Hello
1. CKEditor
I have just installed new WBCE 1.3.
It is not possible to paste text using any of CKEditor paste buttons.
Following message is displayed:
Your browser doesn't allow you to paste this way. Press CTRL+V to paste (or CTRL+Shift+V)
Paste buttons do not work in FF, Opera and Chrome.
2. WBCE 1.3 - permissions
It is not possible to change permissions for files and catalogues in WBCE settings.
Best Regards
Gawi
Bug confirmed but concerning :
https://github.com/ckeditor/ckeditor-dev/issues/469
It seems to be a feature not a bug : -(
We test if there is some Workaround.
2.
Cannot confirm the Issue on my testserver..
So i have a few questions and comments :
You are sure you are not on a windows server as windows does not support permissions?
The file permissions dialog only affects new files created by WBCE it has no effect on files that already exist.
Exactly what is not working? The Dialog does not save the settings or freshly created files still got false permissions ?
Thanks for the report!
Norbert
Unfortunately i can confirm the bug regarding the settings for file and folder permissions at options (Grundeinstellungen). Changing the values here has no effort. I'll open an issue for that.
Regarding the CKE issue:
Just for the record, this is no WBCE CMS issue but a general problem with CKE.
As far as I can remember, pasting into CKE was since ever a hazzle. In former versions, Ctrl-V did not work directly and you had to click on the paste button first. So now it's the other way round, the paste buttons do not work but Ctrl-V.
It's weird indeed, but I think we have to wait until these issues are fixed by the CKE guys.
Thank you for information.
CKEditor
As concerns paste buttons behaviour - in my opinion it is not feature. Many CMS users very often just copy text and paste it using "Paste as a plain text" or "Paste from Word" buttons. It allows to remove all unnecessary formats from text.
If paste button does not work users will paste it using CRTL+V. It means a lot of strange formats in the html code of page.
Anyway we need to wait for solution from CKEditor.
Permissions:
The Dialog does not save the settings - settings show 666 for files and 777 for catalogues.
Regarding CKE: We don't see this as a "feature" neither! We will try to include the paste modules from CKE 4.6 into 4.7 to restore the functionality. Specially on tablets/smartphones you often can't just press CTRL-V / CTRL-Shift-V, so this needs to be fixed.
About the permissions: the reason is that the permission settings only work when "show advanced options" is activated. In the default view, the permission settings should not be displayed. Well, they are displayed anyway, but the changes are not applied. If you click on "show advanced options" first and then change the permissions, the changed values are saved.
We will fix this issue as soon as possible.
Thank you florian. It is possible to set permission if advanced options are displayed.
Best Regards
Gawi
About CKE
Just had a word whith Collinax.
Right now you got 2 Options:
1. Leave it as it is :-(
2. Uninstall CKE and install version 4.6 , which is still available in the addon repo.
https://addons.wbce.org/pages/addons.php?do=item&item=1
We try to to find a solution for the 4.7 Version as soon as posssible.
Maybe it would help to post a comment in :
About file permissions
Bug fixed in recent master on github.
Thx for reporting :-)
Here is the bugfix for the backend themes:
https://forum.wbce.org/viewtopic.php?id=1683
It's a bit confusing that two different questions/bugs are discussed in the same topic, so I would prefer to stick to the CKEditor copy/paste issue here and (if necessary) continue the discussion about the preference settings in the mentioned thread.
