I have done fresh installation right now.
Unfortunately the CKEditor not working. No signs at all.
Default installation.
Help, please!
Ubuntu server 18.04
WBCE Version: 1.4.5
PHP Version: 7.2.24
Which language do you use in the WBCE backend?
Which browser?
Please press F12 to open the browser's developer tools and choose "console", are there any JS errors (red text) displayed?
I tried different backend languages: russian, english, latvian
Please check the error console of the browser as described and have also a look at Admintools > Error Log Viewer, if there are any entries.
Try also to uninstall / reinstall CKE. (Download here)
Errors:
Failed to load resource: the server responded with a status of 404 (Not Found)
Uncaught ReferenceError CKEDITOR is not defined at modify.php?pageid=1:115
Check your config.php. If there's a slash at the end of WB_URL, remove it.
Thank You for response. No extra slash. The WBCM is installed into sub directory.
define('WB_URL', 'http://mail.balvurcb.lv/test');
Are you sure? I can see here a double slash, and that only happens if there's an unwanted trailing slash in the config.php.
Sorry, it was for one moment. As experiment I add slash at the end, test it, and remove it. Now it is no slash.
define('DB_CHARSET', 'utf8');
define('TABLE_PREFIX', 'wbce1_');
define('WB_URL', 'http://mail.balvurcb.lv/test'); // no leading/trailing slash or backslash.
define('ADMIN_DIRECTORY', 'admin'); // no leading/trailing slash or backslash. A simple directory name only.
require_once(dirname(__FILE__).'/framework/initialize.php');
// end of file -------------
Uninistalling / Re-installing CKE as mentioned in #4 above did not help either?
I have another message in debug console (Firefox)
Cannot download (script) with source http://mail.balvurcb.lv/home/test/modul … .js?t=K87C
There is an extra word "home" in the path.
No results
is there a .htaccess in the root, or any other way of URL/path rewriting?
NB: WBCE has no problems being installed in a subdir and/or on a subdomain, might be an issue with the server's configuration.
I would never use a mailserver for website testing anyway. If you need webspace for testing WBCE, have a look at bplaced, there you can get some webspace with PHP and a database for free.
OK Thanks for response. Seems to be server. I appreciate Your help. There is no .htaccess
No rewrite rules.
May be... I use symlinks to web directory. Files actually placed in users directory, then symlink to /var/www/html
Yes, If I install into /var/www/html/sub-folder directly, all works.
Thank You!
