WBCE Version: 1.5.0
PHP Version: 7.4.23
NIA 0.3.5
NWI 5.0.7
I'm trying to get some control over how the Preview Image ( .mod_nwi_teaserpic ) or lack there of, is displayed. Essentially, I want to hide the teaserpic img scr= code, if there is no Preview Image.
The reason is that I have border, box-shadow and padding styles applied to the class - .mod_nwi_teaserpic img
as well as a box-shadow style on the - a img:hover
So, even when there is no Preview image, these styles still get applied:
(note the square boxes. The top one is a link (has Content_long), the bottom is not (does not have Content Long))
The NIA section uses the following template:
<div class="mod_nia">
<h2 class="latest_news">{{ lang.TXT_HEADER }}</h2>
{% for news in newsItems %}
{% if news.TS_POSTED_WHEN > 0 %}
<div class="mod_nwi_group">
<div class="mod_nwi_teaserpic">
{% if (news.CONTENT_LONG or news.HASGALLERYIMAGES) %}
<a href="{{ news.LINK }}">{% endif %}<img src="{{ news.IMAGE }}" />{% if (news.CONTENT_LONG or news.HASGALLERYIMAGES) %}</a>{% endif %}
<div class="mod_nwi_teasertext">
<a href="{{ news.LINK }}">{% endif %}<h3>{{ news.TITLE }}</h3>{% if (news.CONTENT_LONG or news.HASGALLERYIMAGES) %}</a>{% endif %}
<div class="mod_nwi_metadata"><!--{{ news.DISPLAY_NAME }} | -->Published {{ news.TS_PUBLISHED_WHEN | date(lang.DATE_FORMAT) }}</div>
{{ news.GROUP_IMAGE }}
<div class="mod_nwi_shorttext">
{{ news.CONTENT_SHORT}}
<a href="{{ news.LINK }}">{{ lang.TXT_READMORE }}</a>
{% endif %}
<div class="mod_nwi_spacer"><hr /></div>
{% endif %}
{% else %}
{{ lang.TXT_NO_NEWS }}
{% endfor %}
</div>There are four Preview Image scenarios as far as I can tell:
Preview Image with Content_Long
Preview Image without Content_Long
no Preview Image and no Content_Long
Content_Long without Preview Image
Scenario 1 is not a problem, everything displays as I would like.
Scenario 2 - This works fine after this solution - To prevent the hover styles from displaying, I implemented this code ( https://forum.wbce.org/viewtopic.php?pid=28134#p28134 ):
<a href="{{ news.LINK }}">{% endif %}<img src="{{ news.IMAGE }}" />{% if (news.CONTENT_LONG or news.HASGALLERYIMAGES) %}</a>{% endif %}Scenario 3 - I removed the default placeholder image (as suggested here - https://forum.wbce.org/viewtopic.php?pid=38003#p38003 ), but even though there is no Preview Image, the img code is still there, so the img styles are applied to it:
<img src="" />
</div>Scenario 4 - Even though there is no Preview Image, because there is Content_Long, the link code and img code are there, all styles are applied:
<a href="https://www.mysite.com/posts/welcome-message-21/"><img src="" /></a>
</div>If there is not Preview image, I want to hide the associated code, either:
<img src="" />or
<a href="https://www.mysite.com/posts/welcome-message-21/"><img src="" /></a>I played around and tried:
{% if (news.IMAGE) %}
{% endif %}But that did nothing.
I would gladly provide a link through PM, if that would be helpful.
Thank you.
Beitrag geändert von florian (22.09.2021 16:49:40)
I tried to reproduce the issue, but in my test environment (with the same PHP, WBCE, NWI and NIA version), the behaviour using
{%if (news.IMAGE) %}
{% endif %}
</a>
{% endif %}
{% endif %}worked as expected, e.g. the image is only shown if the post actually has an image.
losttrip
Thank you for your support!
I must have overlooked something when I tried adding the
{%if (news.IMAGE) %}{% endif %}and testing. Perhaps tired eyes were at fault.
